Old 10-08-2016, 06:59 PM   #1
MrManatee
MrManatee is on a distinguished road
2000 L-Series 2.2L Wagon
Default Front Wheel Noise - Not the Bearing
Hey, long time lurker here.
I've been getting a very loud growling noise from my 2000 SW2 over the last couple of weeks. It happens when I get up to speed (about 40km/h) and it goes away when I turn left.
Since the noise went away with wheel direction I immediately figured it was the front driver's side bearing. Today, I swapped out the bearing hoping to solve the problem.
After changing everything out and going for a test drive, I found that the growling noise was still there, and it still only goes away if I turn left.
Does anyone have any idea if there would be another cause for this type of noise? I'm stumped.
Add to MrManatee's Reputation
Rate the quality of this post and help MrManatee reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
MrManatee is offline   Reply With Quote
Old 10-08-2016, 07:46 PM   #2
Default Re: Front Wheel Noise - Not the Bearing
CV joint.
To test requires a very tight very low speed circle. Roll up one window and make the turn in the opposite direction, open window side. Listen for 6 periodic pops for each turn of the car wheel or 3 crunches sounding like a handful of potato chips being squeezed. Turn and speed must be such as to cause body roll. Switch open windows and turn direction until you figure out which side the noise is coming from. Try to keep the speed at about 5 mph or so. The outer CV will have 6 distinct pops/rotation and the inner CV will have 3 more muffled crunches/rotation. This tests the axle joints,
Old 10-13-2016, 02:50 PM   #3
marko16
marko16 has a spectacular aura aboutmarko16 has a spectacular aura aboutmarko16 has a spectacular aura about
Or it still can be the wheel bearing. I had one that only had a bad inner race and made a noise in the wrong direction. I replaced the supposed good side and it went away.
Add to marko16's Reputation
Rate the quality of this post and help marko16 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
marko16 is offline   Reply With Quote
Old 10-14-2016, 07:55 PM   #4
If you can count then you can tell the difference.
Old 10-15-2016, 07:12 AM   #5
Ricketts
Ricketts is just really niceRicketts is just really niceRicketts is just really niceRicketts is just really niceRicketts is just really nice
2000 SC1
OldNuc, that is pretty cool information about determining whether it is a CV joint of not. Is that specific to Saturns or can that test apply to other brands as well?
2000 SC1 - Bone Stock
No power windows, no power locks, no AC, no cruise control...just a good DD that has nothing to break on it
Add to Ricketts's Reputation
Rate the quality of this post and help Ricketts reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Ricketts is offline   Reply With Quote
Old 10-15-2016, 09:56 AM   #6
Generally true for CV axles. Outer joint usually 6 balls and inner 3 needle bearing rollers. Easy to test by hand as you can feel it then but under load they make quite a pop.
Front Wheel bearing are loose with no noise Petey S-Series Tech 9 08-08-2016 08:00 PM
Wheel bearing? Front end noise ion skater6912 Ion Tech 21 12-09-2014 09:27 AM
Front end noise, wheel bearing or cv axle?? hatrik8 S-Series Tech 13 03-03-2012 04:18 PM
Front end noise, wheel bearing? freakerz S-Series Tech 5 01-05-2007 02:46 PM
Front wheel bearing noise SL2abuser S-Series Tech 8 09-27-2003 11:27 PM
