Old 04-17-2010, 06:13 PM   #21
patty_b
patty_b is on a distinguished road
Default Re: Strut Replacement With Pictures on a 2000 SW2
After replacing both front strut assemblies with monroe quickstruts, I'm getting a creaking sound from the right side when I turn the steering wheel.
I'm hoping that after the springs settle, this noise will go away. I checked the location of the spring end (where it seats on the rubber) and it's not pushing one of the rubber bumps up to the metal.
Any suggestions for what to do if the problem doesn't fix itself?
Thanks
Add to patty_b's Reputation
Rate the quality of this post and help patty_b reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
patty_b is offline   Reply With Quote
Old 04-18-2010, 03:03 AM   #22
mrbios
mrbios is a jewel in the roughmrbios is a jewel in the roughmrbios is a jewel in the rough
mrbios's Avatar
1997 SW2
Originally Posted by patty_b View Post
After replacing both front strut assemblies with monroe quickstruts, ...
My Monroe SensaTrac (regular, not quick stut) makes the same noise on the right strut and it has not gone away and I installed the strutes over a year ago. I just ignore it. Also, in my case I used after market springs.
Add to mrbios's Reputation
Rate the quality of this post and help mrbios reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mrbios is offline   Reply With Quote
Old 10-09-2016, 11:06 AM   #23
s.patrick
s.patrick is on a distinguished road
Thumbs Up Re: Strut Replacement With Pictures on a 2000 SW2
Excellent Post Barnowl, THANK YOU and thanks to those who created this extremely helpful website !!!
Wanted to share some helpful information I've collected; perhaps others may find this useful:
Saturn / GM Parts
801 W Hwy 83
McAllen, TX 78501
(866) 423-9926
8am - 6pm M-F
8am - 4pm Sat.
gmpartsonline dot net
Genuine Original Equipment Replacement Parts
GetSaturnParts dot Com
Heritage Cadillac
716 Belair Road
Bel Air, MD 21014
800-743-5376
Harbor Freight Bushing Press - Bench Shop Press - $79.99
6 ton A-Frame Bench Shop Press
Rear knuckle-to-lateral link bolt / Hardware:
I found the following from an earlier post: M14x2x230 and found GM OEM part number to be: 11516464
Found: gmpartsonline dot net for above part number
Lateral rod WASHER (Left or Right): Part Number: 10268814
Lateral rod NUT (Left or Right): Part Number: 11516382
OTHER GOOD POSTS on SATURNFANS:
2 good post w/ detailed info & illustrations:
Subject titled
: Energy Suspension bushings installation, thoughts, PICS!
Thread=192814
Subject titled: How-To; SC1 Suspension Bushings Replacement
Thread=2096421
Other good posts on SATURNFANS:
Subject titled: S-Series Torque Specifications
Thread=44221
Subject titled: how do you adjusting rear wheel toe in?
Thread=131483
Subject titled: how to replace lateral links:
Thread=184941
Special tool, people here have called it, that connects FRONT "Lateral Link" to cross-member:
homedepot dot com Husky T55 Torx 3/8 in. Drive Bit Socket $1.97 /each
NOTE: I've read in another post this Torx bolt isn't used to adjust alignment - only the back or rear bolts from REAR Lateral Link to Cross-member are adjusted during the alignment process.
Subject titled: Re: Struts and Shocks - Saturn SC1
Thread=193835
Subject titled: Strut Replacement With Pictures on a 2000 SW2
Thread=67077
Maybe helpful for some: Check:
aftermarketsuspensionparts dot com
Energy Suspension Bushing Options:
Rear End Control Arm Bushing Set
Part Number: 18.3102 for $53.98
OR
HyperFlex Master Kit Saturn S Series 91-02
Part Number: 18.18101 for $99.40
energysuspensionparts dot com
Add to s.patrick's Reputation
Rate the quality of this post and help s.patrick reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
s.patrick is offline   Reply With Quote
2000 LS2 3.0 V6 Timing Belt Replacement Pictures aaront L-Series General 11 09-25-2016 11:32 PM
97 SW2 Strut replacement gregorye70 S-Series Tech 6 08-15-2008 10:48 AM
Strut mount problems 00 SW2 opus S-Series Tech 7 06-12-2007 11:21 PM
Strut Replacement How-To 2000 SW2 BarnOwl S-Series Tech 2 12-17-2005 05:13 PM
'97 SW2 Strut Replacement & Wheel Alignment stu S-Series Tech 9 11-02-2005 05:16 PM
