Old 08-16-2007, 04:47 PM   #1
David 93 SL2m
David 93 SL2m is a jewel in the roughDavid 93 SL2m is a jewel in the roughDavid 93 SL2m is a jewel in the roughDavid 93 SL2m is a jewel in the rough
David 93 SL2m's Avatar
2004 VUE 2.2L
2007 ION-3 Sedan
Happy Changing the serpentine belt on the Ecotec
Under the hood of my 2004 VUE with the 4 cylinder Ecotec engine there isn't a diagram showing how the serpentine belt is routed around the tensioner and other components. I'd like to change the serpentine belt myself. If anyone has done this already would you please share advice and any tips? Thanks in advance!
As of May 2018
∙ 2004 VUE 123K
∙ 2007 ION3 112K
Past
∙ 1993 SL2 212K
∙ 1993 SC2 140K
∙ 1996 SC2 157K
∙ 1996 SC2 126K
∙ 2001 SC2, 145K
∙ 2002 L200 20K
∙ 2002 SL1 129K
Add to David 93 SL2m's Reputation
Rate the quality of this post and help David 93 SL2m reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
David 93 SL2m is offline   Reply With Quote
Old 08-19-2007, 09:42 PM   #2
Bigdaddy94sc2
Bigdaddy94sc2 is on a distinguished road
Bigdaddy94sc2's Avatar
2006 ION-2 Sedan
2005 VUE 3.5L
Default Re: Changing the serpentine belt on the Ecotec
It is really pretty easy. It goes in an oblong circle, with the tensioner holding force in the downward direction. There are only 3 pulleys it goes around.... Just make sure to look at it before you take it off. Use a 3/8" drive ratchet to relieve tension on the tensioner, and you are off!
IIRC, there is a diagram in the owners manual.
GM, Saturn, and ASE certified Technician. Always glad to try to help, just ask!!! Now own an 06 ION.2 as of 7/2/06 with 2988 and counting (7/28/06) 13131 as of (1/8/07) 24901 as of (7/30/07)
Add to Bigdaddy94sc2's Reputation
Rate the quality of this post and help Bigdaddy94sc2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Bigdaddy94sc2 is offline   Reply With Quote
Old 09-01-2007, 10:12 AM   #3
David 93 SL2m
2004 VUE 2.2L
2007 ION-3 Sedan
Happy Re: Changing the serpentine belt on the Ecotec
You are right, the diagram is in the owner's manual. Here is a scan of the diagram from my 2004 VUE owner's manual. It is sort of hidden. It was toward the back on page 6-17 just a few pages before the index.
As of May 2018
∙ 2004 VUE 123K
∙ 2007 ION3 112K
Past
∙ 1993 SL2 212K
∙ 1993 SC2 140K
∙ 1996 SC2 157K
∙ 1996 SC2 126K
∙ 2001 SC2, 145K
∙ 2002 L200 20K
∙ 2002 SL1 129K
Old 09-01-2007, 03:11 PM   #4
David 93 SL2m
2004 VUE 2.2L
2007 ION-3 Sedan
Okay I changed the serpentine belt, but it was not easy. I chose to use a Goodyear Gatorback Poly-V belt, part number 4050400.
The square 3/8" hole for the tensioner is closer to the pivot point than the diagram shows us. There is little room for a 3/8" drive socket wrench. The handle on my socket wrench was not long enough to give me enough leverage so I had to use a "cheater bar" meaning a short length of hollow metal tube over the handle of my socket wrench. To access the tensioner and the areas the serpentine belt snakes around, I removed the front right wheel and the splash shield. There are two-piece plastic rivets holding the splash shield in place, like those two-piece plastic rivets we have for the splash shields in the front wheel wells of the S-Series cars. In case anybody doesn't know, we remove these two-piece plastic rivets but first removing the inner portion by prying with a screwdriver, then the outer portion easily pulls out.
Warning: After removing the front right wheel I saw a hole in the frame that leads to a 15mm bolt. Could this be for the tensioner? Yes - but not for releasing the tension on the belt. Rather it is for removing and replacing the tensioner itself. In other words, don't mess with this bolt when removing/replacing the serpentine belt!
Note to Engineers for Saturn parts: If this tensioner ever gets redesigned then please reposition the 3/8" hole for releasing tension on the belt so it is farther away from the pivot point on the tensioner, ideally closer to the position shown in the slightly incorrect diagram found in the owner's manual. This will allow us to more easily turn the tensioner when removing/replacing the serpentine belt. I hope this makes sense. Thanks.
As of May 2018
∙ 2004 VUE 123K
∙ 2007 ION3 112K
Past
∙ 1993 SL2 212K
∙ 1993 SC2 140K
∙ 1996 SC2 157K
∙ 1996 SC2 126K
∙ 2001 SC2, 145K
∙ 2002 L200 20K
∙ 2002 SL1 129K
Old 09-03-2007, 03:19 PM   #5
David 93 SL2m
2004 VUE 2.2L
2007 ION-3 Sedan
I bought one of these today and removing/replacing the serpentine belt on my Saturns will not be a problem ever again! The bar is flat, nearly 2 feet long, has a 3/8" drive "cube" at one end, and has a thick red plastic handle about 5" long at the other end. It also comes with a 14mm crowfoot, and a few other pieces. The price was $30.
Craftsman Serpentine Belt Tool
Sears item# 00941831000 Mfr. model# 41831
http://www.sears.com/shc/s/p_10153_12605_00941831000P
As of May 2018
∙ 2004 VUE 123K
∙ 2007 ION3 112K
Past
∙ 1993 SL2 212K
∙ 1993 SC2 140K
∙ 1996 SC2 157K
∙ 1996 SC2 126K
∙ 2001 SC2, 145K
∙ 2002 L200 20K
∙ 2002 SL1 129K
Old 09-12-2007, 06:18 PM   #6
zombierepellent
zombierepellent is on a distinguished road
1995 SL2
I had no problem getting to my tensioner but the problem i did have was keeping everything on the right pulleys. My suggestion is instead of doing it from the top. Take the passenger wheel off and the skirting out. then you can do it all facing it.
It's not custom if the check engine light isn't on.
Add to zombierepellent's Reputation
Rate the quality of this post and help zombierepellent reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
zombierepellent is offline   Reply With Quote
Old 12-03-2010, 09:47 PM   #7
firehawk618
firehawk618 is on a distinguished road
Don't know if this works on the Vue but on the L series just remove the whole air cleaner assembly for much more access. To make it even better if you're equipped remove the front engine mount. Then it's wide open and very do-able from the top.
Add to firehawk618's Reputation
Rate the quality of this post and help firehawk618 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
firehawk618 is offline   Reply With Quote
Old 12-23-2011, 09:04 PM   #8
David Lewis
David Lewis is on a distinguished road
The just changed the S-Belt on my sister's Ion and let me tell you that Craftsman Serpentine Belt tool was unfortunately no help to me I thought that I was going to have it made after reading David 93 SL2m Post but it wasn't to be. Maybe another car but not an Ion.
The Problem was very little room to play with and due to the way the tensioner was "Clocked" I couldn't get the extension of the tool to fit in the tensioner from the top.
The solution you ask I took one wire hanger and took it apart to make a wire to which I then threaded across the pivot of the tensioner and the pulley. We then tied the other end of the wire to a poll or a bar and then lift the bar it should lift the tensioner. Problem solved.
Add to David Lewis's Reputation
Rate the quality of this post and help David Lewis reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
David Lewis is offline   Reply With Quote
Old 01-03-2014, 10:26 PM   #9
billysvue
2005 VUE 2.2L
2005 2.2 ECOTEC:::::::
I too tried a serp. belt "tool" but to no avail( for same reasons given above.)
I ended up blocking the engine behind and with a jack below.
Removed the motor mount once it was safe to do so( everybody supported) and jacked it up slightly. I still didn't have enough room to get a 3/8" ratchet, so I ended up using a crowbar(3'long) to push the engine over a skosh to get the ratchet in...
Tension off, belt off, then came removal of the tensioner itself to remove a very tired pulley.
I believe the torque to be 33 ft-lbs for the fastener( tensioner to engine).
TOmorrow's another day.
'17 Suby Forester
I'm a secondhand vegetarian.
Cows eat grass, I eat cows.
Add to billysvue's Reputation
Old 11-14-2014, 12:16 PM   #10
skylanedriver21
skylanedriver21 is on a distinguished road
skylanedriver21's Avatar
2007 VUE 3.5L
I changed one on a 2003 2.2L this week and agree with zombierepellent, pulling the wheel and skirting is well worth the 5 minutes it will take you to do it. I used a C-clamp to retract the tensioner but could not route the new (stiff) belt around the crank pulley until I got access to it in the wheel well. Wasted 30 minutes trying to save 10 minutes with the wheel and skirt.
Add to skylanedriver21's Reputation
Rate the quality of this post and help skylanedriver21 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
skylanedriver21 is offline   Reply With Quote
Old 01-08-2015, 09:16 AM   #11
jacek_p
jacek_p is a jewel in the roughjacek_p is a jewel in the roughjacek_p is a jewel in the roughjacek_p is a jewel in the rough
jacek_p's Avatar
2003 ION-2 Sedan
I agree, the easiest way is 2 people job, one under, one above.
This video gave me an idea how to pivot the tesioner. I went ahead and purchased the little tool @HF (only $4):
https://www.youtube.com/watch?v=0SrwXmnI-_c
Add to jacek_p's Reputation
Rate the quality of this post and help jacek_p reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jacek_p is offline   Reply With Quote
Old 03-26-2015, 02:18 PM   #12
willburrino
willburrino is on a distinguished road
I just signed up here to say........
THANK YOU SO MUCH
I watched a dozen plus videos showing a different motor where you crank the pulley "up" just using a 13mm socket or something along those lines but it's a different design (Without the oblong bracket assembly)
I didn't even consider (or see) the square hole in the assembly and had literally tried 1) Grabbing and pulling with my hand (I'm not strong enough) 2) Pushing it up from under the car (My arms aren't tiny enough) and 3) grabbing the bracket with a slide hammer and pulling up (My slide hammer is too big!)
You saved my knuckles and prevented the neighborhood kids from learning quite a few new 4 letter words, many thanks to you again.
Patiently waiting until the day my cavalier is reduced to a pile of a rust and is relegated to a only a bad memory,
Will
Add to willburrino's Reputation
Rate the quality of this post and help willburrino reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
willburrino is offline   Reply With Quote
Old 04-03-2015, 04:49 PM   #13
KCW
KCW is on a distinguished road
2004 VUE 2.2L
Changed the belt on my 2004 VUE today, after 160k miles it was pretty cracked, but still working.
Between my son and I we found two things that make it quick with no special tools.
You will need two zip ties about 8 to 10 inches long, and a piece of pipe, 3/4 or 1" dia, about 12 to 18 inches long, and ideally two people.
Take the wheel off with the car on jack stands and take off the plastic well liner as other posts have suggested.
To get the tension off the belt there is no way you are going to get a 3/8" drive wrench on the square hole, not on a vue, but here is what you do instead.
First, the best place to pull the belt off is from the engine compartment on the alternator pulley, because it is the smallest diameter pulley. Take one of your zip ties and put it around the belt just below the alternator pulley, and leave yourself a loop about 2 or 3" long.
Now the other person lie under the car with a length of pipe or conduit. At the end of the tension arm, about where the free spinning pulley is, there is a nice bump or nipple on the bottom side of the arm. you can put one end of the pipe with the nipple in the end, so it wont slide off. the nipple is not big, but its big enough to keep the end from sliding off. If you try to push it up with a long screwdriver, or a breaker bar, it will slip, and you will slam your hands into all kinds of nasty sharp rusty things under the car.
So, you are using the pipe or conduit, right? OK with both hands push up with about 50 lbs of force. It helps if you wear a heavy leather / welding glove on your left hand, or fold over some heavy cardboard or similar material so you can push on the end of the pipe/conduit without it cutting into your palm. The tensioner arm will push up about 2", push it all the way till it stops.
now the person in the engine compartment pull the loop of belt off the alternator pully with the zip tie loop. This keeps you from getting your fingers between the belt and the pulley, just incase the person pushing the tensioner lets it go too soon. It will come off easy.
Once the loop is off the alternator pulley, relax the tensioner, pull the belt off the other two pulleys, and put the new one back in the same position.
Take your other zip tie and make another loop on the new belt like the last one. With the belt in place on the other two big pulleys, person on the ground push the tensioner all the way up again with the pipe, and person in the engine space pull the belt onto the alt pulley with the zip tie, use a big screwdriver to help push it sideways if you need to. The new belt will be a little tighter and stiffer. Just don't get your fingers between the belt and the pulley.
when its on, let the tensioner loose, and snip the zip tie off the belt.
this will only take about 20 minutes, and any able body person can push the tension up as described.
If you are stuck and your really have to do it alone, you could make a piece of conduit about 18 to 20" long, and when you push the tensioner up, push a couple pieces of 2x4 or something similar the right size to hold the pipe in place, while you do the engine compartment part, but if you do this, be very careful.
If the pipe slips there is a lot of force on that tensioner, and your face is right there under the car.
The task in the engine compartment is not hard, as long as you use the zip ties.
Hope this helps.
special tools are nice if you have them
but when you don't, you don't.
Add to KCW's Reputation
Rate the quality of this post and help KCW reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
KCW is offline   Reply With Quote
Old 04-03-2015, 05:46 PM   #14
billysvue
2005 VUE 2.2L
Originally Posted by KCW View Post
To get the tension off the belt there is no way you are going to get a 3/8" drive wrench on the square hole, not on a vue, .
I got a ratchet on mine.
Spend a few minutes removing passenger side motor mount and you can.... see my post- a few above.
'17 Suby Forester
Old 04-03-2015, 08:36 PM   #15
KCW
2004 VUE 2.2L
maybe your Vue is a different year than mine, and maybe the L series cars have more room, but a rachet head 3/8" drive was not even close to fitting between the metal plate and the tensioner.
There is no reason to remove the engine mounts, you literally reach up with the short pipe and PUSH the tensioner up as I described from the bottom. It takes about 3 seconds to push it up.
Its not hard as long as you hook the end into the nipple on the pulley end of the tensioner.
Old 04-03-2015, 08:39 PM   #16
KCW
2004 VUE 2.2L
maybe you could finangle a 3/8" breaker bar in there instead of a ratchet head and fish it into the square hole
but I don't have one of those either.
Old 04-03-2015, 09:12 PM   #17
billysvue
2005 VUE 2.2L
maybe your Vue is a different year than mine, and maybe the L series cars have more room, but a rachet head 3/8" drive was not even close to fitting between the metal plate and the tensioner..
By removing the mount, you can push the engine over to get the clearance needed.
Throw up your details in your sig.
'17 Suby Forester
Old 09-04-2016, 10:38 AM   #18
Yodler
Yodler has a spectacular aura aboutYodler has a spectacular aura aboutYodler has a spectacular aura about
2009 AURA XR
2009 Saturn Aura XR, Ecotec 2.4 engine
Grind inch bolt ( inch overall length) into 3/8 square to fit into 3/8 hole in tensioner. Use open end inch wrench on Head of bolt. Raise tensioner with wrench and use wire to attach box end of wrench to engine lift hook. Remove and install new belt. I used duct tape on wrench and head of bolt to keep it all together and make it easier to maneuver into tensioner.
No need to remove engine mount, raise vehicle etc., Most time consuming job was grinding the bolt! Changing belt took a few minutes.
Add to Yodler's Reputation
Rate the quality of this post and help Yodler reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Yodler is offline   Reply With Quote
About serpentine belt and belt tensioner xybaby S-Series Tech 5 01-04-2010 11:42 AM
Changing the v6 serpentine belt binkers L-Series Tech 17 12-05-2009 07:48 AM
Timing Belt And Serpentine Belt obsidian52 L-Series Tech 3 06-06-2009 08:23 AM
Changing Serpentine Belt Laga Ion Tech 6 01-11-2007 01:54 PM
Changing / Replacing Serpentine Belt cmswq3 S-Series Tech 6 01-30-2003 11:29 AM
