Old 07-25-2013, 11:03 AM   #1
Scouser
Scouser will become famous soon enoughScouser will become famous soon enough
1994 SL1
Default 94 SL1 High Idle with codes 13 and 32
Afternoon all;
I at least have my daughter trained to pull over right away and call me if she detects anything wrong with her 128,000 mile 94 SL1. So earlier this morning I got a call from her saying that the check engine light on and that it was idling high.
I went and pulled the codes and looked them up in the official Saturn service manual at the library. Thirteen maps to O2 Sensor Open/Not Ready. Thirty two maps to EGR system fault.
Has anyone seen the combination of these two codes at the same time before, and do the codes point to something other than the O2 sensor and EGR valve.
FYI: I recently replaced the head gasket, inlet manifold gasket and EGR gasket. I also checked the operation of the EGR valve and O2 sensor recently when I was troubleshooting a different issue, and they seemed to work OK.
Thanks.
Add to Scouser's Reputation
Rate the quality of this post and help Scouser reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Scouser is offline   Reply With Quote
Old 07-25-2013, 12:33 PM   #2
Scouser
1994 SL1
Default Re: 94 SL1 High Idle with codes 13 and 32
I just went and picked the car up from about 3 miles from the house. The engine has had plenty of time too cool down since she left it there this morning.
Anyway, when I started it, it was idling at about 2,000 rpm. I drove it home using the same route she left this morning. By the time I got home the engine was warm and it was still idling high - about 1,500 rpm. The check engine light never came on again though. It's obviously a bit warmer now than it was then, but the temperature gauge looked normal - about 1/3.
Oh, I also changed the TPS about a month ago. I'm going to let the engine cool down and then check the operation of the EGR valve, the O2 sensor and the TPS.
Old 07-26-2013, 10:18 AM   #3
With as many posts as you have and no other info related to maintenance/parts replaced, was the two-wire coolant sensor replaced with a brass one? Another source for high idling would be a vacuum leak from lines, old hoses suffering dry rot.
Old 08-01-2016, 05:57 PM   #4
Scouser
1994 SL1
When I was poking around I found that the small hose from the inlet manifold to the MAP sensor had rotted and come loose. $5 for an assortment of small rubber hose connectors and it was as good as new.
Old 08-01-2016, 09:59 PM   #5
...... And did it correct your problems?
2005 Ion 2 high idle w/no codes rickystarshine Ion Tech 0 03-28-2012 03:45 PM
SL1 2002 High Idle w/ SES codes SL1Queen S-Series Tech 1 06-12-2011 10:36 PM
SL1 2002 High Idle w/ SES codes SL1Queen S-Series Tech 2 06-12-2011 09:37 PM
1997 SL High Idle, EGR DTC codes king_tim S-Series Tech 12 11-06-2008 01:44 PM
Cylinder 1 misfire and High Idle Codes lateknightucd S-Series Tech 16 11-14-2007 06:02 AM
