Old 06-30-2016, 11:06 AM   #1
Cgisick
Cgisick is on a distinguished road
Default Coolant overheating and dumping contents.
I have a 2001 saturn sc2 and have had an on going issue for the past few years off and on. If I let my car idle for too long say at a drive through or stopped by a train, steam will start to rise from the passenger side of my hood and as soon as I kill the engine I can hear as see the entirety of the content of my coolant resevoir dumping onto the ground. Upon inspection the cap of the resevoir has blown off and the tank is empty. This has happened multiple times and I have replaces the thermostat temp sensor, and a couple of hoses which stopped the problem for about a year or so. Recently however my car has had a couple of instances where I will start the car and it sputters, almost dieing, and it idles rough, and now it is dumping all of my coolant again't and popping off the resevoir cap. Huge headache ! Anyou help would be very much appreciated!!
Add to Cgisick's Reputation
Rate the quality of this post and help Cgisick reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Cgisick is offline   Reply With Quote
Old 06-30-2016, 11:37 AM   #2
Default Re: Coolant overheating and dumping contents.
The what, now?
Do you mean the ECTS, this thing below?
Does your radiator fan turn on when you turn the AC on, or when the temp gauge reaches past half?
Old 06-30-2016, 11:48 AM   #3
toggenburg
toggenburg is a splendid one to beholdtoggenburg is a splendid one to beholdtoggenburg is a splendid one to beholdtoggenburg is a splendid one to beholdtoggenburg is a splendid one to beholdtoggenburg is a splendid one to beholdtoggenburg is a splendid one to beholdtoggenburg is a splendid one to behold
toggenburg's Avatar
Are you saying that the coolant cap is actually "blown off" its threads???
Have you checked ^^ above, and replaced with a new cap from the parts store, or just put the same cap back on?
Old 06-30-2016, 02:14 PM   #4
bachands
bachands is a splendid one to beholdbachands is a splendid one to beholdbachands is a splendid one to beholdbachands is a splendid one to beholdbachands is a splendid one to beholdbachands is a splendid one to behold
Replace the cap as suggested above. The older the cap gets, the more it loses its ability to keep pressure (especially in neglected cooling systems with dirty/contaminated fluid). So just replace the cap with a new one that can hold the pressure.
Also, if the heater core (or any part of the cooling system really) is clogged, this may be causing excess pressure buildup. Flush the system with the thermostat removed to fix this.
Add to bachands's Reputation
Rate the quality of this post and help bachands reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bachands is offline   Reply With Quote
Got pics of your trunk and factory contents? Dust Ion Red Line 0 01-20-2014 12:40 PM
Problems navigating contents of MP3 CD 07VUE Vue General 3 04-24-2010 05:48 PM
Overheating, oil in coolant res GlennCoco S-Series General 26 11-10-2009 09:41 AM
Dumping all coolant GlennCoco S-Series Tech 10 05-06-2008 03:14 PM
coolant Boiling over - overheating - help! fashions S-Series Tech 12 08-22-2007 05:03 AM
