Old 06-08-2016, 10:17 PM   #1
Carlsonnr
Carlsonnr is on a distinguished road
Default Part Number
Hello all so over the last few months its been getting warmer and now with the increased heat my 1996 SW2 is overheating and coolant comes pouring out on he passenger side. I Asked my dad about it and he thinks i need a coolant fan switch/sensor. The only thing is i can't find that anywhere. Any help would be greatly appreciated.
Add to Carlsonnr's Reputation
Rate the quality of this post and help Carlsonnr reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Carlsonnr is offline   Reply With Quote
Old 06-08-2016, 10:47 PM   #2
Default Re: Part Number
Guide: http://www.saturnfans.com/forums/showthread.php?t=37884
Just about any parts store should have the ECTS in stock for $10-$15.
Old 06-08-2016, 10:51 PM   #3
Chub
Chub will become famous soon enough
Chub's Avatar
The first thing I would check is to see whether or not your coolant reservoir cap is up to the challenge of a fully pressurized system. If the coolant cap does not allow the cooling system to pressurize properly than the coolant has a much lower boiling point and will make a big mess when it boils over. The cap may look good even if it is not and this is probably the most likely part to fail with the symptoms you described. A new cap should only cost you $5 at the regular auto stores. The coolant fan is triggered through the PCM by the ECTS reading. If you have not replaced the resin ECTS with a brass one that is also something that you should make sure to do.
1995 SC2: Back on the road again after my second engine rebuild in two years.
Add to Chub's Reputation
Rate the quality of this post and help Chub reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Chub is offline   Reply With Quote
Old 06-09-2016, 02:58 PM   #4
^ ^ ^ Yeah, you want to be sure of what the problem is before you start buying parts. Could be a $5 cap, could be the ECTS, could be a dead water pump.
Does it overheat when you are going down the road, or only when you are stopped/driving slowly? Does the engine fan turn on?
Old 06-09-2016, 06:10 PM   #5
Carlsonnr
The fan doesn't turn on. I've monitored it with a scan tool and the temp reads to ~200 degrees and it boils over at that point. It overheats at a stand still
Old 06-09-2016, 08:14 PM   #6
Chub
Chub's Avatar
Definitely sounds like a bad coolant reservoir cap to me if it is boiling over at that temperature. The fan should not come on until you are around 220F or so. If you want to make sure the fan works just jump it or turn on the A/C.
Name this part and part number (2007 Ion-2) Swat ss Ion Tech 4 04-04-2014 10:15 PM
flex pipe exhaust part or part number? blaisedaddy Astra General 5 10-18-2012 06:14 AM
BCM Part Number mihalak L-Series Tech 1 04-08-2011 09:41 AM
Need a part number johnny95sl2 S-Series Tech 6 02-23-2009 10:14 AM
2007 Ion: Looking for a Part Number (and maybe the part) fosgate3 Ion Tech 2 06-05-2007 08:03 PM
