Old 12-14-2014, 08:31 PM   #21
Neutron
Neutron is on a distinguished road
Neutron's Avatar
1994 SL2
2001 SW1
Default Re: fog lights for 1994 SL2
The 55W H3 bulbs are working well. I needed them TODAY, as it turned out.
It's good to have the fog lights back in service.
1994 SL2 Automatic AC 220,500 miles
Add to Neutron's Reputation
Rate the quality of this post and help Neutron reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Neutron is offline   Reply With Quote
Old 12-14-2014, 08:39 PM   #22
Yes, they actually do serve a purpose.
Old 12-14-2014, 11:23 PM   #23
choc citysaturn
choc citysaturn is on a distinguished road
choc citysaturn's Avatar
1994 SL2
Glad you got them working. Fog lights and a spoiler on a first gen sl2 give it a finished look that the other sedans don't have.
My number one goal is to make my saturn better now than when I bought it in Dec of 1993. IMPORT FIGHTER
Add to choc citysaturn's Reputation
Rate the quality of this post and help choc citysaturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
choc citysaturn is offline   Reply With Quote
Old 12-15-2014, 10:16 AM   #24
Neutron
Neutron's Avatar
1994 SL2
2001 SW1
HELPFUL TIP: For those replacing your old fog light assemblies, KEEP the metal retainer clip on the back side of the reflector.
You will need it, as the replacement reflector assembly does not have a metal retainer clip!
Old 12-15-2014, 11:42 AM   #25
Those clips should be available as a replacement part as they are generic and tend to get lost. If I needed 1 or 2 I would call up one of the specialty lamp suppliers.
Old 12-15-2014, 02:44 PM   #26
Neutron
Neutron's Avatar
1994 SL2
2001 SW1
For reference, the part number for those fog lamp retainer clips is:
GM Part Number: 16502951
Old 12-15-2014, 02:57 PM   #27
Check that number as it does not come up as good.
I found some listings and they claim it is a discontinued part as far as GM is concerned. There are just 2 dealers that list having it. Back to the aftermarket high end lamp dealers.
Old 12-15-2014, 04:20 PM   #28
Neutron
Neutron's Avatar
1994 SL2
2001 SW1
http://www.gmpartsonline.net/parts/1...&siteid=215055
http://parts.nalleygmc.com/products/.../16502951.html
http://oemcats.com/oem-parts/16502951.html
https://www.parts.com/index.cfm?fuse...OCKET-RETAINER
http://www.finditparts.com/products/...otors-16502951
Old 12-15-2014, 04:41 PM   #29
I found all of that, it is a discontinued part from GM and GM Parts Direct does not even list it. It is a dead number that will not get a part.
You have to get one from someone who sells the European aftermarket lamps.
Old 05-15-2016, 03:30 PM   #30
hudypete1
2007 ION-3 Sedan
i like my fog lights. just installed them from a junkyard find.
Peter
Add to hudypete1's Reputation
Fog Lights, Dashboard lights, Tail lights are not working dbunch Vue Tech 8 10-10-2015 03:33 PM
1994 SC2 warning lights Tward21 S-Series Tech 0 02-04-2014 04:41 AM
No dash/running lights, but DTR, Hi/Low, brake/signal lights work??? Haybale S-Series General 1 08-09-2013 11:49 PM
Guage cluster lights, gear shifter light, and running lights not working. DracoAzule Ion Tech 1 12-11-2011 08:05 PM
Accidentally burned out instrument panel lights and reverse lights on '99 Saturn Sc1 tjohnny42 S-Series Tech 19 07-09-2008 09:40 PM
