Old 05-10-2016, 07:32 PM   #1
jarellg
jarellg is on a distinguished road
Default 1994 SL1 blowing white smoke after shifting out of 1st gear
Hi all. So this just started happening today driving home from work. I noticed when shifting from 1st to second I get a puff of white smoke coming from the tail pipe. I also noticed it while down shifting from 4th to third. It doesnt over heat. Still runs smooth, just that dang white smoke that just started happening. Any body have any ideas of what it could be??
Thanks
Add to jarellg's Reputation
Rate the quality of this post and help jarellg reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jarellg is offline   Reply With Quote
Old 05-10-2016, 08:33 PM   #2
billr
billr is just really nicebillr is just really nicebillr is just really nicebillr is just really nicebillr is just really nice
Default Re: 1994 SL1 blowing white smoke after shifting out of 1st gear
What PCV valve do you have? That would be the easy answer. If the PCV system isn't letting oil into the combustion chambers, then it is probably valve-stem seals or piston rings. I'm guessing the rings, since they seem to pass a lot of oil on nearly all of these engines.
Add to billr's Reputation
Old 05-10-2016, 10:10 PM   #3
jarellg
I have the original pcv system and the original rings. My car does burn ALOT of oil. I have to put like almost a quart every week. What happens if i keep driving it like that....other than it might blow more and more smoke. I ask because Im going to have to drive it like that until at least this weekend....
Old 05-10-2016, 10:15 PM   #4
billr
Cancel the panic, it can probably go for years like that.
Old 05-10-2016, 10:27 PM   #5
jarellg
really?. how would i know if the rings or the valve stem seals are bad. it runs at 80 mph with no problem never over heating...
Old 05-11-2016, 01:19 PM   #6
marko16
marko16 has a spectacular aura aboutmarko16 has a spectacular aura aboutmarko16 has a spectacular aura about
Yours is close to where mine is. I'm at 411xxx miles and mine is clattering now quite loudly. Can I guess that an oil control ring completely collapsed. I'm at a quart every 200-250 so I've just been dumping used oil in. I figure I'll go 400 more miles and call it good. I need half the AV system off this car for another.
Funny it took so long to see mine smoke, now it's pretty bad.
Add to marko16's Reputation
Rate the quality of this post and help marko16 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
marko16 is offline   Reply With Quote
Old 05-11-2016, 02:01 PM   #7
check coolant level, see if it has dropped any? and check reservoir for any 'milkshake'?
Old 05-12-2016, 01:10 PM   #8
marko16
Compression tests are the real test, but given these cars burn oil, most of the oil is through the rings.
'99 SL2 Blowing White Smoke takashinho S-Series General 3 03-20-2012 07:43 AM
my 2002 l200 is blowing white/grey smoke out of the tailpipe big L-Series Tech 9 02-11-2010 04:20 PM
Blowing white/grey smoke out of tailpipe sw1davis S-Series Tech 8 11-11-2009 02:33 PM
Blue Smoke or White Smoke...some defintions 2NDSOUT S-Series Tech 0 07-08-2009 09:16 AM
Blowing smoke after an oil change ??? WTH browntown3 S-Series Tech 8 06-20-2008 03:35 PM
