Old 05-10-2016, 10:42 AM   #1
JuhKayRay
JuhKayRay is on a distinguished road
1993 SC2
Default Steering wheel will not come off
This is my first post. i have a 93 SC2 i got a couple of months ago, and everything works great except for when you turn on the right turn signal, the left brake light flashes. after looking all over the car we decided it was a problem with the multifunctional(?) switch behind the steering wheel. we took out the air bag, took out all the bolts, but the steering wheel will not come off. even went out and got a puller! we've tried gaming on the center nut on the puller and lubricated it and everything and it won't move at all.
Add to JuhKayRay's Reputation
Rate the quality of this post and help JuhKayRay reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
JuhKayRay is offline   Reply With Quote
Old 05-10-2016, 11:13 AM   #2
trottida
trottida's Avatar
Default Re: Steering wheel will not come off
Stupid question but I have to ask it; did you remove the nut holding it on?
Current rides
2001 SL1 MT (410,500 km @ 11/2017)
1999 SL2 MT (251,500 km @ 11/2017)
2011 Suburban LT (101,450 km @ 11/2017)
:canada:
Add to trottida's Reputation
Old 05-10-2016, 11:26 AM   #3
JuhKayRay
1993 SC2
yeah dude. we even opened my trunk and hooked a chain from the steering wheel to my grandpas Ram and tried to put tension on it, still didn't move once. i guess thats what happens when you pay $200 for a car
Old 05-10-2016, 11:32 AM   #4
Special Forces
Special Forces has a spectacular aura aboutSpecial Forces has a spectacular aura aboutSpecial Forces has a spectacular aura about
Special Forces's Avatar
2006 ION Red Line
Little bit of heat. They tend to sieze on. I've broken a steering wheel with a wheel puller before. Some carefully placed heat should wake up both alloys.
/// Need rebuilt valve bodies? PM Me. \\\
//// Why bother with ebay when I'm right here? \\\\\
Valve bodies built to order
Please PM me about valve bodies, do not post a visitor message.
Add to Special Forces's Reputation
Rate the quality of this post and help Special Forces reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Special Forces is offline   Reply With Quote
Old 05-10-2016, 12:02 PM   #5
JuhKayRay
1993 SC2
okay ill try to find a heat gun when i get home
Old 05-10-2016, 01:11 PM   #6
Special Forces
2006 ION Red Line
I was thinking more like MAP gas. A heat gun may not be enough. You'll want to get the shaft pretty hot but very precisely so as not to melt any of the surrounding plastic.
Old 05-10-2016, 05:08 PM   #7
billr is just really nicebillr is just really nicebillr is just really nicebillr is just really nicebillr is just really nice
"gaming on the center nut on the puller"
I gotta ask... what is "gaming" on puller? Did you tighten the puller and then hit (axially) on the puller screw with a hammer?
Add to billr's Reputation
Old 05-11-2016, 01:21 PM   #8
marko16
marko16 has a spectacular aura aboutmarko16 has a spectacular aura aboutmarko16 has a spectacular aura about
Always hit the nut behind the wheel.
Add to marko16's Reputation
Rate the quality of this post and help marko16 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
marko16 is offline   Reply With Quote
Replacing steering wheel - how do I make sure coil behind steering wheel is ok? vikasevan S-Series Tech 2 12-29-2014 12:32 PM
Something in the steering snapped, steering wheel turns around and around, tires wont BullyCanadian Vue Tech 20 03-26-2014 11:23 AM
leather steering wheel question/steering wheel comment 2006 ion2 Ion General 4 04-29-2010 06:27 PM
2003 Vue Steering Wheel Tunk Noise When Turning Wheel kencat Vue General 6 03-05-2010 06:06 PM
rubbing noise steering wheel/steering column on 04 Vue ynotps Vue General 6 03-03-2005 07:59 PM
