Old 11-27-2015, 11:06 PM   #1
theinternetthug
theinternetthug has a spectacular aura abouttheinternetthug has a spectacular aura about
2001 L-Series 2.2L Sedan
Default E-brake sticking in cold weather
Does anyone know why my e-brake might be sticking as it gets colder? It's becoming quite inconvenient. I have a 2001 l200 with 172k miles on it.
Add to theinternetthug's Reputation
Rate the quality of this post and help theinternetthug reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
theinternetthug is offline   Reply With Quote
Old 11-28-2015, 08:35 AM   #2
s3nfo
s3nfo's Avatar
2001 L-Series 3.0L Wagon
Default Re: E-brake sticking in cold weather
Water inside the cable sheath freezing and locking the cable in place.
Jerry N
Groucho Marx
Add to s3nfo's Reputation
Old 11-28-2015, 09:28 AM   #3
Russet
2002 L-Series 3.0L Sedan
That and Rust will do that as well. And if you never used it there a good chance it no longer functions.
Add to Russet's Reputation
Russet is online now   Reply With Quote
Old 11-28-2015, 11:07 AM   #4
theinternetthug
Do you know where I could find a diagram of how it's run underneath the car? Or how I could go about fixing the problem? I use it daily so it sucks to have to let my car warm up for fifteen minutes before it finally releases.
Old 11-28-2015, 04:07 PM   #5
Russet
Get a Haynes to see if it shows you how to check the Parking Cable.
Old 11-28-2015, 08:29 PM   #6
born again
born again is a glorious beacon of lightborn again is a glorious beacon of lightborn again is a glorious beacon of lightborn again is a glorious beacon of lightborn again is a glorious beacon of lightborn again is a glorious beacon of light
2000 L-Series 2.2L Wagon
The cheap way is just don't apply it. If you have a 5 speed MT then put it in first gear when you park it. This condition will only get worse as it gets colder. You will likely have to replace the rear cables between the brakes and the equalizer. I did this a couple of years ago. Note - there are rubber boots on the cables that are supposed to prevent water from entering between the cable and the sheath. The rubber is likely rotted out and gone or shredded. You may be able to squirt some penetrating oil down there to displace the water, but this will only work temporarily. Grease would be better, but it is hard to get it any distance down the sheath.
Add to born again's Reputation
Rate the quality of this post and help born again reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 11-29-2015, 11:55 AM   #7
s3nfo
s3nfo's Avatar
Rust locks the brakes all the time, not just when it's cold outside, as specified in the OP's question.
Jerry N
Groucho Marx
Cold Weather anmire S-Series Tech 14 08-26-2013 08:22 AM
2004 Vue Manual Tran Shuddering on Cold Start in Cold Weather sixstringmonk Vue Tech 5 02-20-2012 07:28 PM
e-brake sticking mjoekingz28 S-Series Tech 0 01-10-2010 04:14 PM
'03 Ion and cold weather AbbyNN8 Ion General 3 12-21-2005 02:30 PM
Cold weather... todaresqSL2 General Saturn Discussion 20 01-29-2005 07:03 PM
