Old 11-23-2015, 10:56 AM   #1
LuvMy1994
LuvMy1994 is on a distinguished road
1994 SL2
Default Turn Signal Fuse Keeps Blowing After Changed Tail Bulbs
Hi everyone!
I've read a few threads here and haven't quite found the answer to my problem, so I thought I'd ask.
I changed all the tail lights in the passenger's side assembly of my 1994 Saturn SL2, then immediately turned the car on to make sure the lights were working. Just because I felt like it, I flipped the turn signal on, and it didn't work! The fuse had blown, although it had been working perfectly before.
I replaced the fuse and flipped the signal on again. I saw the arrow light up for a split second on the dashboard, then nothing. The fuse had blown again. Tried it again. Same results.
The tail lights seem to be working fine. I did not touch the rear turn signal when I replaced the other bulbs, but could I have messed something up just by pulling out the tail light assembly?
Any help will be greatly appreciated.
Add to LuvMy1994's Reputation
Rate the quality of this post and help LuvMy1994 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
LuvMy1994 is offline   Reply With Quote
Old 11-23-2015, 11:31 AM   #2
billr
billr is just really nicebillr is just really nicebillr is just really nicebillr is just really nicebillr is just really nice
Default Re: Turn Signal Fuse Keeps Blowing After Changed Tail Bulbs
Could you have caused this problem while changing the lamp? Sure, in fact it appears likely that you did. Careful visual inspection is the first step here, look for a cut or break in wire insulation in the first 12" or so from the tail-light assembly. Take apart as much as you need to inspect adequately.
Add to billr's Reputation
I keep blowing my turn signal fuse when I turn the key to on. hazards work theiss04 S-Series Tech 22 02-11-2015 05:59 AM
Fix for tail light fuse constantly blowing ericfragola S-Series Tech 0 08-22-2013 12:31 AM
Turn signal bulbs s-seriesguy Ion Mods 11 09-10-2009 10:33 AM
turn signal bulbs.... twizted_ion Ion General 15 05-28-2006 10:43 PM
How to change turn signal bulbs in an 01 SC2? zeldamaster S-Series General 17 04-05-2006 08:44 PM
