Go Back   SaturnFans.com Forums > Site Information > Community Center > Introductions & Greetings
Old 11-01-2015, 07:26 PM   #1
lhb113
lhb113 is on a distinguished road
2000 SL1
Question 2000 SL tensioner pulley problems
I have replaced the alternator, the tensioner pulley and a serpentine belt. I started the car up and it squealed like before and the belt broke. I am clueless as how to get my car up and running. Your input would be appreciated very much.
Thanks,
Lynn
Add to lhb113's Reputation
Rate the quality of this post and help lhb113 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
lhb113 is offline   Reply With Quote
Old 11-01-2015, 08:25 PM   #2
Default Re: 2000 SL tensioner pulley problems
When the belt was first removed and alternator removed/replaced, did you check all the remaining pulleys for freedom to rotate? Its too easy to presume none of the other pulleys are seized but it never hurts to manually turn them to feel for wear and replacement if necessary. Since the belt broke, you may as well check each pulley to be sure none are seized. Finding one may be the cause.
In the future, it would be better to post problems in the S-series tech forums instead of the community center.
Old 11-02-2015, 07:08 PM   #3
lhb113
2000 SL1
Happy Re: 2000 SL tensioner pulley problems
Thank you. This is the first time I have joined a forum. So, I don't know the ropes. I appreciate your response. The other pulleys in the engine are fine.
Old 11-03-2015, 09:00 AM   #4
The only reason its suggested to post in the specific forums similar to your model is due to members habituated to perusing forums with the same model. More members reading in the forum for the S-series are likely to reply than the few who look in the Community or Introduction forums.
Tensioner pulley cecilmeyer S-Series Tech 1 10-01-2014 08:15 PM
2000 saturn ls2 Tensioner pulley stud specs? sin_d84 L-Series Tech 0 01-30-2011 06:12 PM
Are the serp belt idler pulley and tensioner pulley the same part - 93 DOHC?? 93goldsl2 S-Series Tech 6 04-10-2010 01:03 PM
Idler pulley and/or tensioner pulley replace nmsaty S-Series General 11 03-20-2006 06:02 PM
tensioner pulley=idler pulley? bhall10 S-Series Tech 32 05-24-2004 07:37 PM
