Old 09-02-2015, 08:25 PM   #1
Shadow_tek001
Shadow_tek001 is a glorious beacon of lightShadow_tek001 is a glorious beacon of lightShadow_tek001 is a glorious beacon of lightShadow_tek001 is a glorious beacon of lightShadow_tek001 is a glorious beacon of light
Shadow_tek001's Avatar
Default Oil Leaking, passenger side
Hi folks, My mom has a 2008 Saturn outlook XR. She's at 170k Klms (about 100k miles)
It's developed an oil leak on the passenger side, and drips mainly at the drain screw (it's not that though). I've looked around online, and found a lot of info on the Acadia forums about the timing chain cover gasket leaking... would that be consistent with outlooks?
Also, apparently normal is the power steering fluid leaking...
What's common?
Anyone else run into this?
Any Tips?
Thanks!
Edward
Add to Shadow_tek001's Reputation
Rate the quality of this post and help Shadow_tek001 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Shadow_tek001 is offline   Reply With Quote
Old 09-11-2015, 10:43 PM   #2
Penrod
Penrod has a spectacular aura aboutPenrod has a spectacular aura about
Penrod's Avatar
2009 Outlook XE
Default Re: Oil Leaking, passenger side
Have you tried wiping everything down and doing a really good leak check with a mirror and flashlight? Or take off the top cover and verify it's nothing leaking from there and going down the engine. Hope you find the leak and it's an easy and cheap fix.
Add to Penrod's Reputation
Rate the quality of this post and help Penrod reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Penrod is offline   Reply With Quote
Old 09-11-2015, 10:53 PM   #3
Shadow_tek001
Yeah, it's incredibly difficult to get to anything on that engine unfortunately :-(
Edward
Old 10-22-2015, 12:55 PM   #4
Doug C
Doug C's Avatar
2008 Outlook XE
Attention Re: Oil Leaking, passenger side
A couple wks back I had a oil change done at a dealership (only reason it is done similiar setup to one of those quick lube joints ) The wrench turner mentioned this time about a probable oil leak on the passenger side.
I noted but did not take them up on their offer to make an appt. since unless emergency work required I won't give this dealership any biz due to one of their mechanics breaking my wind deflector and leaving greasy palm prints all over it and hood ...and saying it was broke previous !
Time to make an appt. at a (trusted) third party garage, and see if they come up with the same items, (also oil change crew prev. made mention, of a minor tranny leak).
doug c
Add to Doug C's Reputation
Old 10-31-2015, 12:30 PM   #5
Doug C
Doug C's Avatar
2008 Outlook XE
http://www.cbc.ca/news/canada/windso...vers-1.3290936
Hmmm when will our newer ones reportedly start burnin' too, and then 2-3 more yrs before a 'recall' !?
doug
Old 10-31-2015, 03:06 PM   #6
Shadow_tek001
Won't happen, the oil comes from the front of the engine, no where near the exhaust manifold
Edward.
Old 11-01-2015, 07:36 PM   #7
onefunkar
onefunkar's Avatar
2008 Outlook XR
2007 AURA XR
yes acadia would be the same as the outlook
Add to onefunkar's Reputation
leaking passenger's side trans output shaft seal saturnsctwo S-Series Tech 25 05-10-2015 09:42 PM
Help please! Leaking coolant underneath passenger side amahoney225 S-Series Tech 9 07-11-2014 09:21 PM
passenger side nozzle not working, driver side weak liweih21 Aura General 13 04-04-2013 11:31 PM
Heater core leaking into passenger side hilco5 L-Series General 8 04-05-2007 11:05 AM
Water leaking in from passenger side door Lurker1999 S-Series Tech 6 11-23-2005 02:30 PM
