Go Back   SaturnFans.com Forums > Site Information > Support Forum for Canadian Saturn Owners
Old 08-11-2015, 07:51 PM   #1
vinyl361
vinyl361 is on a distinguished road
Default Ses p0410
I am working on my friends 2000 Saturn S series. The SES light continues to come on and the secondary air injection system is the fault code. I have researched the system and have searched for solutions to the problem, unfortunately I cannot find the problem. I am looking for suggestions at this point. I have taken off and checked the air pump. The ECTS has been changed and the air pump comes on for 30 seconds when the engine is cold. There is good vacuum at the shut off valve and through the solenoid. There is good air flow through the shut off valve. I took off the exhaust manifold, (it was all plugged up) and cleaned the connection pipe. I thought cleaning the manifold would cure the problem, but it hasn't, the SES light continues to come on with the P0410 code. I do not know what else to do or look for at this point. I cannot pass inspection like this and need some help.
Thanks,
Mark
Add to vinyl361's Reputation
Rate the quality of this post and help vinyl361 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
vinyl361 is offline   Reply With Quote
Old 08-12-2015, 10:31 AM   #2
BV22
BV22 is a glorious beacon of lightBV22 is a glorious beacon of lightBV22 is a glorious beacon of lightBV22 is a glorious beacon of lightBV22 is a glorious beacon of light
2002 SC1
Default Re: Ses p0410
Based on the diagnosis you report, it sounds like you left out a critical step in your system clean out. From the backside of the exhaust manifold, the injected air passes through 4 holes in the head into the exhaust stream. If these air passages in the head are plugged, the air does not get injected.
BV22
2002 SC1 5M
313k 07/18
Add to BV22's Reputation
Old 08-12-2015, 03:43 PM   #3
vinyl361
I cleaned all the passages on the head thoroughly, just forgot to mention it.
Old 08-12-2015, 05:02 PM   #4
Does this help?
Old 08-12-2015, 10:08 PM   #5
vinyl361
Thank you, very helpful. I will try and go over it all and post back.
P0410 bluefever S-Series Tech 2 11-23-2014 06:00 PM
P0410 Border Walker S-Series Tech 8 08-29-2014 08:46 AM
Help!!!!!! P0410 sbnj_barneck S-Series General 11 10-16-2012 01:44 PM
P0410 Huskerville S-Series Tech 5 08-23-2009 09:47 AM
P0410 x2 L200Pilot L-Series Tech 3 09-05-2007 11:27 AM
