Old 03-22-2015, 10:38 PM   #1
vikasevan
vikasevan has a spectacular aura aboutvikasevan has a spectacular aura about
vikasevan's Avatar
2001 SL2
2004 VUE 3.5L
Question Passenger side floor is wet ...what should I look for?
car has sunroof but drain tube was not clogged ....
check AC drain with a ball pen ..it was not blocked
what else?
is it possible for power steering fluid to go inside the car and flood passenger side floor ?
Add to vikasevan's Reputation
Rate the quality of this post and help vikasevan reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
vikasevan is offline   Reply With Quote
Old 03-22-2015, 10:45 PM   #2
Tommie
Tommie is a jewel in the roughTommie is a jewel in the roughTommie is a jewel in the rough
1996 SL1
2002 SL1
Default Re: Passenger side floor is wet ...what should I look for?
What year and model? A blow gun with compressed air on those drains to double check but do not go full blast...The drain on early SL use these rubber door flaps in the wiper cowling that do not work very well in heavy rain and may spill over into the inside of the car. The later 2000 and up are redesigned and handle heavy rain better.
Add to Tommie's Reputation
Rate the quality of this post and help Tommie reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Tommie is offline   Reply With Quote
Old 03-23-2015, 12:09 AM   #3
vikasevan
vikasevan's Avatar
2001 SL2
2004 VUE 3.5L
It's 1997 sl2
Can you tell me where exactly is the location of those rubber door flaps in wiper cowling?
I mean should I remove both wipers to reach there?
Old 03-23-2015, 06:09 AM   #4
lamping.ap
lamping.ap will become famous soon enoughlamping.ap will become famous soon enough
Are you loosing coolant? I suspect a leaking heater core.
Add to lamping.ap's Reputation
Rate the quality of this post and help lamping.ap reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
lamping.ap is offline   Reply With Quote
Old 03-23-2015, 09:39 AM   #5
mattwithcats
mattwithcats will become famous soon enoughmattwithcats will become famous soon enough
Seal on windshield may be leaking...
2002 Silver SL2, manual, 5th gear swap (.605), 78,000 miles, black badges,
Pennzoil Ultra Platinum 5W-30, NAPA 41516...
NGK BKR6E-11 spark plugs
Old 03-23-2015, 10:40 AM   #6
BV22
BV22 is a glorious beacon of lightBV22 is a glorious beacon of lightBV22 is a glorious beacon of lightBV22 is a glorious beacon of lightBV22 is a glorious beacon of light
2002 SC1
Also, check the donut seal under the hood near the windshield on the passenger side. This is the fresh air intake for the HVAC and has an oval, flexible seal on the cowl. These can disintegrate or disappear.
BV22
2002 SC1 5M
305k 02/18
Add to BV22's Reputation
Old 03-23-2015, 01:11 PM   #7
Have you touched the liquid?
Green colored (lamping.ap I agree)coolant.
Clear water?
Smell at all?
Old 03-24-2015, 10:36 AM   #8
Tenn
Tenn is on a distinguished road
I had a terrible problem with water on my 99 SC1 passenger side floor for a long time.
The A/C drain tube was not blocked, but it seems as if the seal at the firewall was deteriorated. It was a piece of foam, and the water was dribbling out the end of the drain tube, back down into the evaporator housing.
Basically I just got a piece of plumbers putty, and formed a new seal on the tube to firewall. This was over 5 years ago now, and not a drop has made its way in since.
Good luck on finding on your problem and solution.
Add to Tenn's Reputation
Rate the quality of this post and help Tenn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Tenn is offline   Reply With Quote
Old 03-31-2015, 09:09 PM   #9
vikasevan
vikasevan's Avatar
2001 SL2
2004 VUE 3.5L
I am not sure which part you are referring to...can you explain further or can I see a pic.?
Old 04-01-2015, 07:11 AM   #10
lamping.ap
So, no coolant leak?
He's talking about this:
Old 04-04-2015, 08:36 AM   #11
boatmoter
boatmoter is on a distinguished road
boatmoter's Avatar
1993 SL2
common problem with saturn leaks is the roof drip rails.. my 93 SL2 is bad but for mine they have been discontinued.. but Im sure the ones for a 1999 are available
Add to boatmoter's Reputation
Rate the quality of this post and help boatmoter reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
boatmoter is offline   Reply With Quote
Old 04-04-2015, 11:52 AM   #12
Signmaster
Signmaster is a name known to allSignmaster is a name known to allSignmaster is a name known to allSignmaster is a name known to allSignmaster is a name known to allSignmaster is a name known to all
Since this seems to come up a lot I made this to clarify the areas.
This is in addition to the photo that Lamping.ap put up that shows the other common area. The ZOHC car he shows is unique though!
Old 04-07-2015, 01:26 AM   #13
vikasevan
vikasevan's Avatar
2001 SL2
2004 VUE 3.5L
Thanks I think problem is fixed. Not sure what was the source of leak?
1. I cleaned sunroof drain towards bottom of car.
2. Cleaned ac drain
3. fixed that oval mesh cover towards passenger side.
still conufsed about cowl drains...
when we remove wiper assembly to replace wiper motor there are two holes with rubber flap attached ...I guess those are the cowl drains?
Thanks everyone.
Old 04-07-2015, 07:23 AM   #14
Signmaster
2. Cleaned ac drain
Thanks everyone.
Usually the cause is the oval mesh screen. I've really never understood the point of the thing, as it can be completely covered up if desired. On most cars all it does is allow a little underhood air to possibly mix with the fresh air in the vent system.
The cowl drains should be the ones you describe. I found that firewall photo and used it as it makes the location easier to find. The rubber flap is just one of the versions of the drain.
Old 06-02-2015, 06:08 PM   #15
saturnsctwo
that screen is exposed even when the hood is closed so if water's not supposed to enter it why is it exposed? when the hood is closed you can see the opening. this makes no sense. if water enters it does it go to the evaporator case & drain out the a/c drain? if so that would be a great way to flush out any dirt/debris in the evaporater case while clearing the drain of any obstructions...
Add to saturnsctwo's Reputation
Rate the quality of this post and help saturnsctwo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 06-02-2015, 10:47 PM   #16
driver8
driver8 is on a distinguished road
i had this mystery leak......turned out to be the water pump....? does that make sense.....? lol, well, when i flushed my coolant, and replaced the leaky water pump, it went away.....dont know what solved it actually....but if i recall, i did the flush/exchange first...at a quick lube shop....then couple months later did the water pump...and yea, check your window guides too, make sure your window isn't leaking?
Add to driver8's Reputation
Rate the quality of this post and help driver8 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
driver8 is offline   Reply With Quote
Red Fluid Passenger Side Floor 2000 SC2 bigskinsfan S-Series Tech 10 05-19-2008 04:08 PM
Wet floor on passenger side...but car starts in the rain! lisaNmike S-Series Tech 11 11-07-2006 10:26 PM
98 SL2 Wet Passenger Side Floor LMK S-Series General 10 11-26-2005 10:04 PM
'99 SW2 water on floor passenger side kailuamike S-Series General 2 09-15-2005 08:42 PM
Wet passenger side floor dragonheartck Vue General 4 06-12-2005 01:13 PM
