Old 04-10-2015, 07:00 PM   #1
keithguinn13
keithguinn13 has a spectacular aura aboutkeithguinn13 has a spectacular aura about
Sad Coolant leak (HELP!)
Hey there. I have a 2000 Saturn SL1 with a cooling system problem. The previous owner really didn't take care of this.
This car is the car that got me into fixing stuff. I've gone through a couple resivoir tanks and this recent older one works.
I have been leaking coolant from the bottom of the radiator (took it to the mechanic who said the previous owner installed this NEW radiator wrong).
They said it will last, but not much longer. The other night when I got off of work (keep in mind I've driven it for weeks with no overheating)
it started to lose coolant FAST. I believe it was coming from the cap because there was air trapped in the system. I've pretty much
replaced most of my cooling system so I know it almost in and out and I'm at a dead end. I've tried burping the air to no avail it just boils
out of the top of the cap. When the thermostat opens, air bubbles don't come up and the fluid level doesn't drop at all. I'm wondering
what this could possibly mean? Any help would be much appreciated! Thank you in advance. Should I replace the radiator? (well I'm planning on that anyways :P).
Add to keithguinn13's Reputation
Rate the quality of this post and help keithguinn13 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
keithguinn13 is offline   Reply With Quote
Old 04-10-2015, 09:13 PM   #2
toggenburg
toggenburg is a splendid one to beholdtoggenburg is a splendid one to beholdtoggenburg is a splendid one to beholdtoggenburg is a splendid one to beholdtoggenburg is a splendid one to beholdtoggenburg is a splendid one to beholdtoggenburg is a splendid one to beholdtoggenburg is a splendid one to behold
toggenburg's Avatar
Default Re: Coolant leak (HELP!)
What concentration is your antifreeze, 40% water & 60% pure coolant?
Is/was your coolant green or dexcool orange?
Have you replaced the coolant cap?
Has the thermostat been replaced before any trouble, and if so, is it installed correctly, with the spring part headed in toward the engine, cause if reversed, you will boil also.
Silla radiators off Ebay are good to use, and won't hurt your wallet.
Coolant Leak adam22 S-Series General 11 05-16-2013 05:22 PM
Oil Leak, Coolant Leak, Alternator, Compressor Bobcat124_23456 L-Series Tech 4 03-25-2013 09:13 PM
99' SW2 Coolant Leak axslinger S-Series Tech 8 11-16-2010 11:58 AM
coolant leak SBXLI93 S-Series Tech 11 07-03-2009 07:44 PM
Saturn SL-1 2002 - Coolant Light/Coolant Leak - Muffler noise - Check Engine Light unabelladonna S-Series Tech 1 02-26-2007 11:56 AM
