Old 03-15-2015, 07:13 PM   #1
mrcoachdavis
mrcoachdavis has a spectacular aura aboutmrcoachdavis has a spectacular aura about
Default 6t75 Solenoid removal
Hey all. My first time being on here. Hope there is help out there. Having trouble with a connector so How do I remove the wire harness retainer from the control valve body cover stud and disconnect the control valve body Transmission Control Module (TCM) electrical connector? Picture or video would be great.
Add to mrcoachdavis's Reputation
Rate the quality of this post and help mrcoachdavis reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mrcoachdavis is offline   Reply With Quote
Old 03-15-2015, 07:33 PM   #2
mrcoachdavis
Default Re: 6t75 Solenoid removal
Added a picture
Old 03-15-2015, 10:29 PM   #3
ssicarman
ssicarman's Avatar
The lever arm (different shade grey from the connector) is moved to the right in your picture. On the right side of the lever is a lock tab that you press down to allow the lever to be moved to the tight. As the lever moves to the right it is supposed to lift the connector out of what it is plugged into. In real life you may need to help it along by wiggling the connector outwards as you move the lever.
Add to ssicarman's Reputation
Old 03-25-2015, 05:54 PM   #4
mrcoachdavis
Thank You. I think I will give it a try on Saturday.
Old 05-02-2018, 03:05 PM   #5
TOMMY35
TOMMY35 is on a distinguished road
I am having same problem. Did you push button in at bottom of lever to release this?
Add to TOMMY35's Reputation
Rate the quality of this post and help TOMMY35 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
TOMMY35 is offline   Reply With Quote
Old 05-02-2018, 07:40 PM   #6
satlite440
satlite440 has much to be proud ofsatlite440 has much to be proud ofsatlite440 has much to be proud ofsatlite440 has much to be proud ofsatlite440 has much to be proud ofsatlite440 has much to be proud ofsatlite440 has much to be proud ofsatlite440 has much to be proud of
2001 SL2
in the slot where the red cpa slides in under the center of the hoop of the lever use a pocket screwdriver to press in/down to unlock the 1st stage of the lever hoop/arm..then pull lever to release..
shure you can trust the government,just ask us indians all about it...
heavy line the final protective fire line of the dealership
Add to satlite440's Reputation
Rate the quality of this post and help satlite440 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
satlite440 is offline   Reply With Quote
Old 05-29-2018, 07:16 AM   #7
patrickwilliams
patrickwilliams is on a distinguished road
I needed to get an answer to the same question! Do you have a video tutorial?I think I will give it a try tonight.
http://livecustomwriting.com/blog/a-good-cheap-paper-writing-service-in-the-uk-is-here
Add to patrickwilliams's Reputation
Rate the quality of this post and help patrickwilliams reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
patrickwilliams is offline   Reply With Quote
6T70 6T75 Transmission Repair transtech49 Classifieds 0 12-31-2014 04:41 PM
Help! Power steering pump EVO solenoid removal Upstate Saturn S-Series Tech 11 12-17-2014 07:55 AM
saturn outlook 6t70&6t75 3-5-r failure satlite440 Outlook General 19 01-15-2014 08:55 PM
1-2 Shift solenoid removal rower Vue Green Line 0 05-10-2013 11:45 AM
Outlook Tranny = 6T75 GR898SL2 Outlook General 13 05-19-2006 06:34 AM
