Old 03-20-2015, 07:32 PM   #1
Blammer
Blammer is on a distinguished road
Default 1999 SL2 ignition lock cylinder issues
I have a 1999 saturn SL2.
Key was starting to get difficult to put in the lock cylinder, no biggie.
I will fix this while I have it apart for the following problem.
My problem is, that when you go to turn the key, NOTHING comes on.
You work the key back and forth a bit and you get a smattering of electrical through the system, dash lights and stuff come on like normal before you crank it.
otherwise NOTHING, no electrical at all, as if you didn't even put the key in and turn it.
I suspect it is the ignition switch (directly behind the lock cylinder).
Or would it be something else?
Looking for suggestions before I go spend the cash to get the parts I can't return.
97 SW2 270,000 miles and died when a tree fell on it.
Never argue with an idiot, they will only bring you down to their level and beat you with experience.
Add to Blammer's Reputation
Rate the quality of this post and help Blammer reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Blammer is offline   Reply With Quote
Old 03-20-2015, 09:41 PM   #2
54packman
54packman will become famous soon enough
1998 SW2
2000 SC2
Default Re: 1999 SL2 ignition lock cylinder issues
Yes it does sound like the switch itself is acting up. And not the lock cylinder, try pulling the switch off and see if turns and functions properly, some cars have a sort of drive shaft between the the lock cylinder and the switch which I have seen break.
Add to 54packman's Reputation
Rate the quality of this post and help 54packman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
54packman is offline   Reply With Quote
Old 03-20-2015, 10:57 PM   #3
There is no drive shaft. Your problem sounds like a defective/worn out switch.
http://www.saturnfans.com/forums/sho...9&postcount=50
Old 03-21-2015, 07:42 AM   #4
Blammer
Thanks.
when I pulled the cylinder lock out behind it was a, well, a funny looking piece that the lock cylinder went into. I pulled it out, and screwed up and didn't notice how to put it back together.
that may be the "drive shaft" thing spoke of earlier.
do you have any pictures of that and how it's suppose to look.
after taking out the drive shaft thing I noticed a chunk of metal was stuck in it and it look like it was sheared off.
I'll have to get out my camera and put up some pictures .
Old 03-21-2015, 08:14 AM   #5
No pictures. Take the switch off the back and figure it out. You may have broken it.
It is possible you should be replacing the entire column lock housing assembly. It is a junk yard assembly and after you remove one you will know how to get yours apart. It is all held on there by 2 security screws.
Late 97 to 99 is a definite fit.
Ignition switch and housing pictures.
Loose Column fix
http://www.saturnfans.com/forums/sho...91#post1902891
Housing clamp screw size
M6x1 x 25 mm long, use socket head cap screws.
Ignition Lock Cylinder or Ignition Switch? jzambon S-Series General 12 03-26-2017 03:30 PM
Ignition lock cylinder help! blacktruckryder Vue General 6 06-29-2013 07:00 PM
Ignition Lock Cylinder.... emsvitil Vue Tech 2 07-30-2010 07:12 PM
Ignition Lock Cylinder. Can't get key in. saladdin S-Series Tech 19 05-28-2010 11:58 PM
Ignition lock cylinder MikeNW S-Series General 6 11-18-2009 06:47 PM
