Old 03-02-2015, 09:05 AM   #21
Default Re: 1995 SC2 Timing Problem
Pulling a single plug wire is very hard on coil insulation and NOT recommended. Grounding a single wire is fine though.
The exhaust leak also causes a fouled up mixture which does not help.
Old 03-02-2015, 07:24 PM   #22
zmarrott
zmarrott is on a distinguished road
OldNuc, the exhaust ends after the CAT and isnt the issue. its run like that many times without issue. and ive been getting the code since the exhaust was still stock. it came as a result of the cold air. going to check compression in a bit after i go get the gauge
Add to zmarrott's Reputation
Rate the quality of this post and help zmarrott reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
zmarrott is offline   Reply With Quote
Old 03-02-2015, 07:30 PM   #23
zmarrott
just to check: from left to right the cylinder numbers go 4 1 2 3 correct?
Old 03-02-2015, 07:47 PM   #24
SuperGreen
SuperGreen has a spectacular aura aboutSuperGreen has a spectacular aura about
SuperGreen's Avatar
Yes 4 1 2 3 . Also is your CAI a true cold air intake? I was considering putting a warm air intake but definitely don't want to be popping SES lights..
Add to SuperGreen's Reputation
Rate the quality of this post and help SuperGreen reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SuperGreen is offline   Reply With Quote
Old 03-02-2015, 08:27 PM   #25
zmarrott
it was a true cold air, untill the original filter broke from being too close to the ground. so i took off the lower half of it and now it functions as more of a ram air than a cold air. i presume ram air is what you meant by warm air intake. ram air is a short pipe with usually a pod filter, but it pulling air from the engine bay instead of being routed outside the engine bay. the duct tape is cuz a hole got worn through it from the original battery bracket
Old 03-02-2015, 08:31 PM   #26
zmarrott
and to be honest the ses light is probably cuz of what i did with the intake temp sensor. its not actually in the intake, just dangling in the front corner of the car somewhere
Old 03-02-2015, 08:36 PM   #27
billr is just really nicebillr is just really nicebillr is just really nicebillr is just really nicebillr is just really nice
Are you asking about cylinder order, or firing order? Cylinder #1 is on the passenger-side, cylinder #4 is only the driver-side; 1-2-3-4 left-to-right standing in front of the car looking into the engine bay. I am not talking about firing order here, just actual cylinder locations.
Add to billr's Reputation
Old 03-02-2015, 08:39 PM   #28
zmarrott
going off of the coil packs its 4 1 2 3. ive never seen an inline 4 actually be 1 2 3 4. firing order is probably something like 2 4 1 3. i know how they the basics of how they work, but i need to check when it comes to specific vehicles
Old 03-02-2015, 08:44 PM   #29
As usual, this has become quite confused.
This is how you hook it all up.
Ignition wire routing as seen when looking at the engine and coils from the front, hood open, your left to right.
Engine
1-2-3-4
4-1-2-3
coil towers
Connect the matching numbers with a plug wire.
NOTE:
Your left when standing in the front of the car looking at the engine is your left, the car's right. The passenger side is always the right side when referencing the car.
Old 03-02-2015, 09:36 PM   #30
SuperGreen
SuperGreen's Avatar
LOL obviously your SES is on with the Intake sensor dangling. Alright now I'm not as worried lol.
Old 03-02-2015, 09:47 PM   #31
zmarrott
ok so now that cylinder location is cleared up, thank you oldnuc, if theres a burned valve would i hear anything if i place a stethescope to the top of the headders for each cylinder? havent gotten to the compression check cuz im waiting for my friend to help me with that
Old 03-02-2015, 09:51 PM   #32
Pull the PCM B fuse to shut off fuel and spark and get someone to crank the engine while you listen at he tail pipe. If it is reasonably functional you will hear 1,2,3,4,1,2,3,4 repetitively with the same time spacing and if you have a bad exhaust valve 1 pulse in each group of 4 will be flat. Can not miss it. If it was the 3rd one you would hear 1,2,phht,4
Old 03-02-2015, 10:09 PM   #33
zmarrott
will definitely test that when my friend gets here. and pulling that fuse will be much easier than unplugging each plug and injector for the compression test
Old 03-03-2015, 12:07 AM   #34
zmarrott
so got the compression ressults. cylinders 1 and 2 are pushing about 30 psi and cylinders 3 and 4 are pushing 150-180. thats just confusing to me. i tested from left to right and after getting to cylinder 4 i went back to double check cylinders 1 and 2 and still read 30
Old 03-03-2015, 09:00 AM   #35
Sounds like a blown head gasket. Need to pull the head and look. #1 and #2 are mechanically 180 degrees apart. Be sure to check both head and block for warpage as the engine has been run low on coolant.
Old 03-03-2015, 02:05 PM   #36
zmarrott
coolant is fine at the moment, and if it is leaking to the cylinders, i havent lost much. i havent driven it since saturday. ive only ran it low on coolant once about 3 months ago when the water pump was leaking, but after repairing that it ran fine.
Old 03-03-2015, 02:28 PM   #37
SL19302
SL19302's Avatar
2000 SW2
2002 SL1
I would do a leak down test on both cylinders to see where the leakage is happening, The gasket if blown between the two cylinder will show up.
CHECK YOUR OIL!
Add to SL19302's Reputation
Rate the quality of this post and help SL19302 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 03-05-2015, 04:26 PM   #38
zmarrott
so instead of doing a leak down teat due to how expensive they are, i just pulled cylinder 1 and 2 spark plugs and disconnected their fuel injectors on the hunch that my head gasket break was between the two cylinders and after accidentally leaving all electrical systems on for a day and getting the battery charged at autozone for 2 1/2 hours and a 20 minute jump start, it ran quite well considering the condition the engine is in. cylinders 1 and 2 are bypassed entirely with the exception of their weight. wouldnt idle below 1800 rpm, but kinda cant expect much better on half an engine. went for a drive and no overheat issue at all just minimal power. so thats the status of the car now. so does anyone know of or can find a forum on replacing the head gasket on the DOHC engine? im at work currently and dont have time to search the site yet
Old 03-05-2015, 05:49 PM   #39
How about a link to a head replacement which includes the gasket?
Head replacement and chain remove-replace
http://www.saturnfans.com/forums/sho...d.php?t=168496
Pictures of the entire overhaul process.
DOHC (1995)
https://picasaweb.google.com/1159762...L6UoammvrKEsAE
1995 SC2 clutch problem dude33333 S-Series Tech 10 07-19-2012 08:59 AM
1995 SL2 with EGR Valve Problem abruscino S-Series Tech 4 07-03-2008 01:22 PM
MP3 File of My 1995 SL2 That Dealer Say Needs Timing Chain 95StillRunning S-Series Tech 3 10-23-2006 09:19 PM
Timing chain installation 1.9 SOHC (1995) horndog S-Series General 13 07-12-2005 07:01 AM
Timing belt questions for my SL2 95K miles 1995 jimtmcdaniels S-Series General 3 06-11-2005 01:08 PM
