Old 02-07-2015, 02:37 PM   #1
iSprenk
iSprenk is on a distinguished road
2002 L-Series 2.2L Sedan
Question Turn signal flasher module location
I've been trying to find the turn signal module in my 2002 L200, but I can't seem to figure out where it is. I read somewhere that it's in the area down by your feet on the driver's side. I've taken a picture of what mine looks like. Would anyone be able to point out which one it is?
I'm doing this in order to figure out how to fix the hyperflash caused by the LEDs I installed.
If possible, I'll be getting a replacement flasher (made to compensate for LEDs) from Super Bright LEDs.
Thanks!
Add to iSprenk's Reputation
Rate the quality of this post and help iSprenk reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
iSprenk is offline   Reply With Quote
Old 02-07-2015, 04:24 PM   #2
Russet
Russet will become famous soon enoughRusset will become famous soon enough
2002 L-Series 3.0L Sedan
Default Re: Turn signal flasher module location
I found a schematic are you sure it's not up in the front engine bay? That there from what I found doesn't list the turn signal flasher relay there? Here's that same Left Instrument Panel Fuse Block and Right Side Panel and last engine bay fuse panel.
Add to Russet's Reputation
Old 02-08-2015, 01:02 AM   #3
The turn signal/hazard flasher module is where no one looks, right behind the hazard/4-way flasher button above the radio.
From the service manual;
Remove the instrument panel (I/P) trim panel.
Release the tabs and push on the switch from the back side of the panel.
Remove the switch (1).
Old 02-08-2015, 09:17 AM   #4
s3nfo
s3nfo is a jewel in the roughs3nfo is a jewel in the roughs3nfo is a jewel in the rough
s3nfo's Avatar
2001 L-Series 3.0L Wagon
It's also integral with the flasher module, there's no separate turn signal flasher, the flasher module basically is the turn signal flasher so you can't tweak just the turn signals.
Jerry N
"Politics is the art of looking for trouble, finding it, misdiagnosing it and then misapplying the wrong remedies."
Groucho Marx
Add to s3nfo's Reputation
Rate the quality of this post and help s3nfo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
s3nfo is offline   Reply With Quote
Old 02-08-2015, 12:24 PM   #5
Russet
I kinda figure that...so guess looks like their hazard is not working and they need to replace it.
Old 02-09-2015, 01:50 AM   #6
iSprenk
Yep, I've read about it sometimes being there, but I wasn't 100% sure. Will I be able to replace the relay with one that is compatible with LEDs, like the ones I've seen on superbrightleds.com?
Old 02-09-2015, 03:53 AM   #7
I cannot answer whether or not a modified relay can replace the stock one. There are many different turn signal circuits and modifying with LEDs becomes a custom project.
Old 02-09-2015, 03:56 AM   #8
ayge
ayge is on a distinguished road
2000 SC2
thanks
Add to ayge's Reputation
Rate the quality of this post and help ayge reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ayge is offline   Reply With Quote
Turn Signal Flasher 98TransAm Aura General 3 08-09-2014 06:27 PM
96 sl1 turn signal flasher location rlahrens S-Series Tech 2 03-02-2010 11:43 PM
More turn signal/flasher issues kdhunter S-Series Tech 6 09-02-2008 11:49 AM
Need help with flasher/turn signal failure kssherod L-Series Tech 6 12-03-2007 08:01 AM
Where is the turn signal flasher box???? mellissam Vue Tech 2 08-04-2006 03:02 PM
