Old 12-21-2014, 05:08 PM   #1
vikasevan
vikasevan has a spectacular aura aboutvikasevan has a spectacular aura about
vikasevan's Avatar
2001 SL2
2004 VUE 3.5L
Question Oil on 2 spark plugs
2001 saturn sl2
I was about the change spark plugs and do MMO treatment and when I removed spark plugs two of them No. 2 and 3 spark plugs threads have oil on it ...
does it mean those two piston rings are shot?
How much mystery oil we should add in each spark plug hole?
What type of spark plugs you recommend? how about bosch 4501 which is platinum and iridium mix?
Add to vikasevan's Reputation
Rate the quality of this post and help vikasevan reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
vikasevan is offline   Reply With Quote
Old 12-21-2014, 05:15 PM   #2
93twincam
93twincam is on a distinguished road
1993 SC2
Default Re: Oil on 2 spark plugs
What do you mean by oil on the plugs? On the threads? Or on the electrode? If it's on the threads it's most likely the valve cover gasket leaking.
$300 1993 SC2 finally plugging along with 184K and going up :) 38 mpg!
1993 Foxbody build in slow progress
Add to 93twincam's Reputation
Rate the quality of this post and help 93twincam reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
93twincam is offline   Reply With Quote
Old 12-21-2014, 07:28 PM   #3
ALWAYS USE NGK COPPER SPARK PLUGS ONLY.
Our sattys use a waste spark system (fires 2x) so it will EAT up any other plug and not give the performance you might expect.
Old 12-21-2014, 07:53 PM   #4
wi111y
wi111y is on a distinguished road
1995 SL
1995 SW2
Originally Posted by vikasevan View Post
2001 saturn sl2
I'm going to assume you mean oil on the threads...
Common enough problem, the gaskets around the spark plug seals aren't sealing properly. If it's not enough to work it's way into the chamber and foul the plugs, fixing it is optional. My brother's car never would seal right in that area, and it didn't cause any issues.
'95 SL 5 Speed 220k - DD
'95 SW2 5 Speed 230k - Gone!
'95 Camaro Z28 - Project
'00 Tahoe Z71 - Truck stuff
Add to wi111y's Reputation
Rate the quality of this post and help wi111y reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
wi111y is offline   Reply With Quote
Old 12-21-2014, 08:39 PM   #5
el diablo viejo
el diablo viejo will become famous soon enough
el diablo viejo's Avatar
1994 SW1
2000 SW2
The cam cover is leaking into the spark plug wells, and if enough oil leaks into the well, it can affect spark plug performance. You should think about replacing the cam cover gasket. Do not use the the Bosch plugs. NGK BKR5ESA-11 are the best bet.
97 sl2 a/t 104 K
1989 GMC 3500 454 129 K, 1969 442 455 rat rod
Add to el diablo viejo's Reputation
Rate the quality of this post and help el diablo viejo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
el diablo viejo is offline   Reply With Quote
Considering replacing spark plugs and spark plug wires - Need advice 2002SaturnMan S-Series Tech 25 10-15-2015 07:29 AM
Dealer pricing on spark plug wires and spark plugs. KeithR S-Series General 25 05-19-2011 11:52 PM
1992 SL2: spark, fuel, air, no fire (new air & fuel filter, spark plugs, wires) onixwj S-Series Tech 12 12-11-2009 08:07 PM
Spark Plugs mako462 Vue Tech 5 10-01-2006 10:30 AM
Changed spark plugs and wires, look at old plugs (pics) Chingon S-Series General 12 03-30-2005 02:42 AM
