Old 12-12-2014, 02:47 PM   #1
youngstr11
youngstr11 is on a distinguished road
Default Replace DVD Player with a Raspberry PI
So the DVD in My 2005 Saturn Relay went out about a year ago so I figured I would like to try and setup a Raspberry PI and remove the DVD player. So I pulled the DVD player by removing the 2 screws under the screen. I removed the DVD player from the board and then hooked up to a old DVD player to see if the player would go directly to A/V if the DVD is not present and I was correct.
Now I just need to get a voltage meter to see if the DVD was pulling 5 volts then I can hook up my Raspberry PI B+ to this or figure out where to pull power from. I would also like to find a way to have the Raspberry PI auto shut down when the ignition is turned off.
If you have a wiring diagram for the DVD in a Saturn Relay 2005 that would be really helpful. If you have done anything like and have advise please send it. Thanks
Add to youngstr11's Reputation
Rate the quality of this post and help youngstr11 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
youngstr11 is offline   Reply With Quote
Old 12-12-2014, 04:20 PM   #2
Default Re: Replace DVD Player with a Raspberry PI
Do these wiring diagrams help?
02 SL1 SHOC with oil in coolant: replace head vs replace engine - need advice surreyman S-Series Tech 3 05-02-2010 12:24 PM
Wanted: CD Player Install Kit 01 SC2, Maybe even a CD player itself spencerb Classifieds 0 02-17-2005 12:41 PM
WTB: 91-94 OEM CD player (maybe even tape player) QwikSC2 Classifieds 1 01-07-2005 03:15 AM
FS Audiovox CD player, OEM cassette player 91-94 Lurker1999 Classifieds 0 10-04-2003 04:16 PM
Stock cassette player vs Cd player speaker ?? Scyan S-Series Tech 3 04-24-2003 06:06 PM
