Old 11-30-2014, 01:56 PM   #1
Freak Storm
Freak Storm is on a distinguished road
2002 SL1
Default neutral safety switch or starter?
I've got a 2002 SL1 and have a few instances when there was power, but no crank at all.
Since buying the car about a year ago, it has always needed to be started in neutral.
Just this afternoon, it started fine, drove just a few miles for an errand, went to start it again after 15 minutes or so and nothing.
After 30 minutes checking/wiggling wires and multiple attempts at restarting, etc still nothing.
Then after searching the forums here, saw mention of the NSS. Checked wires, nothing, then I tried tapping on it with a wrench and it started right up.
I don't have a multimeter for testing.
Should I just replace the switch and see?
Thanks in advance!
Add to Freak Storm's Reputation
Rate the quality of this post and help Freak Storm reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Freak Storm is offline   Reply With Quote
Old 11-30-2014, 02:33 PM   #2
billr is just really nicebillr is just really nicebillr is just really nicebillr is just really nicebillr is just really nice
Default Re: neutral safety switch or starter?
I think you could extract those two contacts from the NSS (actually part of the gear selector switch) and jumper them together. If it always starts OK for a while like that, it would confirm that is the problem. Have you adjusted the switch? That could be done with just a test light.
Add to billr's Reputation
Old 11-30-2014, 05:08 PM   #3
Freak Storm
2002 SL1
Haven't tried adjusting the NSS yet.
Will try a jumper and see what happens, although having little time and opportunity in current Michigan weather, I might just replace it and the starter at the same time.
Thanks for the advice!
Old 11-30-2014, 08:22 PM   #4
You do realize that you will have to learn how to adjust that switch if you replace it? I figure you might as well adjust the existing, just as a learning run, even if adjustment doesn't fix it. It's pretty easy to do.
Old 11-30-2014, 08:59 PM   #5
Chazberry
Chazberry's Avatar
Your results may vary, but here's some info . . .
http://www.saturnfans.com/forums/sho...81&postcount=3
Btw - does jiggling the shifter in Park or Neutral have any effect? That might suggest some needed adjustment.
Add to Chazberry's Reputation
Old 12-01-2014, 08:25 AM   #6
Freak Storm
2002 SL1
Thanks Billr, I realize that now, will give it a go!
Chazberry, I've tried jiggling and forcing the shifter and it did nothing. Thanks for sending the link, more troubleshooting ahead!
Old 12-01-2014, 11:39 AM   #7
One method to separating a starting circuit from starter problem would be measuring the START (12v) signal at the starter solenoid, the single small gauge purple wire on its own terminal. Pulling this wire off and measuring it for 12v when someone turns the ign switch to START will verify the entire starting circuit from ign switch to NSS to this wire. As long as the ign switch is held in the START position, 12v should be on this wire. Not seeing 12v means a starting circuit problem. With 12v measured here in START and intermittent starting leaves you with most likely a worn out starter.
Old 12-01-2014, 11:46 AM   #8
Be aware that the contacts in that switch used for adjusting it have a very, very narrow range of angular travel. I find that if you adjust it, then move the shift lever in-and-out of P several times you won't always get a "good" reading each time, it will be intermittent depending on minute slop in the shifting and switch mechanisms. Don't let this bother you, and don't waste time trying to get the switch adjusted to give a "good" reading every time. The working contacts in that switch, those for the shift indication, BU lamps, and neutral safety, all have a much wider range of operation and will be fine.
Edit: I should add... there are many threads here about the joy of adding a long "sense lead" to the small terminal on the starter solenoid (PPL wire), that is a great tool for determining if the problem is in the wiring to the starter (like NSS) or the starter itself. Plus, if it is in the wiring, it gives you a way to force cranking and get out of an inconvenient situation.
Old 12-01-2014, 02:34 PM   #9
^ You are absolutely right and the only reason I state to disconnect this START wire from the starter before measuring it. I cannot stress this enough for anyone crawling under the engine as it easily avoids powering up a starter if this wire is left connected to the starter.
Location of starter and neutral safety switch? sikao S-Series General 7 08-09-2013 10:19 PM
Neutral safety switch help Highmile S-Series Tech 2 12-15-2009 01:15 PM
Neutral Safety Switch????? Clickety_Clack S-Series General 10 12-03-2008 09:24 PM
Transaxle Range Switch\Neutral Start Safety Switch lonelywolf8588 S-Series Tech 2 07-20-2006 07:55 AM
neutral safety switch staroffear S-Series General 1 04-16-2005 10:14 AM
