Go Back Forums > Models > Saturn S-Series > S-Series Tech
Old 10-20-2014, 10:29 AM   #1
wobbles1 is on a distinguished road
1998 SL
Dizzy 98 S-series obd2 codes
hello, iam looking to fix an obd2 issue,
A few months ago i went for an inspection MIL light on. failed. printout read a egr code of pitle malfunction, tried cleaning, no effect. bought new egr from napa replaced it. egr code went away, a few weeks later same code returned. did some internet research, found a site instructing to unbolt egr from engine, but leave pigtail connected. if rpm goes above normal egr passages NOT clogged. my rpm went WAY up. so passages clear. reconnected egr. a week later code goes out then returns this time with a bad front o2 sensor. replaced o2 sensor. codes went away came back, this time egr and a code to do with a evap leak. i put car on lift. hose from engine to evap purge solenoid had come off. i put it back on code went way. over the next few weeks codes (formentioned, minus evap code kept coming back) the codes will come on for a few days (because i drive alot, college and work) then go out, then come back, and so on.
so now i have a egr code, a front o2 sensor code, and a rear o2 code.
(these are the codes that have come up, these include the evap codes that arent there anymore p0442, p1404, p0137, p0401, p0133
thank you very much
any help is greatly appreciated
Add to wobbles1's Reputation
Rate the quality of this post and help wobbles1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
wobbles1 is offline   Reply With Quote Sponsored Links
Old 10-21-2014, 06:17 AM   #2
Highmile's Avatar
Default Re: 98 S-series obd2 codes
Start here:
'95 SL1 554k and counting
95 sl1 496k (rebuilt engine)
Add to Highmile's Reputation
Rate the quality of this post and help Highmile reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
OBD2 diagnostic codes....? captaintrips S-Series Tech 13 12-08-2012 04:48 PM
OBD2 Codes on 2001 Saturn SL1 LJ57 S-Series Tech 9 08-31-2010 01:12 PM
Please help me with these OBD2 codes ..... Hidalgo S-Series Tech 8 02-18-2010 05:15 PM
I need some help with OBD2 codes/ troubleshooting please. WadeNKC S-Series General 4 01-13-2009 04:13 PM
Broken hose and obd2 codes FraX S-Series Tech 2 03-03-2006 09:47 PM
Copyright ©2000 - 2018, vBulletin Solutions, Inc. The Saturn Enthusiasts Site.
