Old 09-09-2014, 05:48 AM   #1
poguy
poguy is on a distinguished road
Default 2005 Ion P0601 code - Which replacement PCM?
I have a 2005 Ion-2 manual transmission, and it has been throwing P0601 PCM checksum. It runs OK after clearing the code, but it is probably time to replace it. Plenty of threads covering P0601 and a big thanks to the posters.
But which one is the right one? Is the number in the upper left the right one? In this case it is:
12596919
But some EBay sellers use the service number, 12589999. And then there is the bar code.
So which one do I use to order another one?
Thanks!
Add to poguy's Reputation
Rate the quality of this post and help poguy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
poguy is offline   Reply With Quote
Old 09-18-2014, 01:26 AM   #2
bern
bern is just really nicebern is just really nicebern is just really nicebern is just really nicebern is just really nice
2004 ION-2 Sedan
Default Re: 2005 Ion P0601 code - Which replacement PCM?
Before replacing PCM for any of the 6 hundred codes make the battery and connections and cables are in good condition. Will the available PCMs have the correct calibration programmed in it? If new it may not be programmed at all.
Add to bern's Reputation
Rate the quality of this post and help bern reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 09-18-2014, 07:59 PM   #3
poguy
Update - Now the P0601 won't clear and the car won't turn over.
Battery connections are OK, reseated connector, no change.
Any suggestions? I saw one place that claims they can do a pre-programmed PCM when you supply the VIN number. Does that make sense?
Old 09-18-2014, 09:10 PM   #4
2006 ion2
2007 ION-2 Sedan
If they have a tech 2 and somehow access to the oem flashes. I would just get a new one from a dealership if you can afford it, a known good one from an 05 or 06 ion.
2007 Saturn Ion 2
2003 Chevrolet venture lt
Add to 2006 ion2's Reputation
Old 09-18-2014, 09:56 PM   #5
satlite440
satlite440 is a splendid one to beholdsatlite440 is a splendid one to beholdsatlite440 is a splendid one to beholdsatlite440 is a splendid one to beholdsatlite440 is a splendid one to beholdsatlite440 is a splendid one to beholdsatlite440 is a splendid one to beholdsatlite440 is a splendid one to behold
2001 SL2
do not plug in a used ecm or an unprogrammed one or you will be sorry..
shure you can trust the government,just ask us indians all about it...
heavy line the final protective fire line of the dealership
Add to satlite440's Reputation
Rate the quality of this post and help satlite440 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
satlite440 is offline   Reply With Quote
2005 Ion 2 code help (car not shifting correctly) hueycoleslaw Ion General 0 10-28-2011 08:19 PM
2005 Ion 2 code help (car not shifting correctly) hueycoleslaw Ion Tech 0 10-28-2011 02:12 PM
P0601 code ---reflash or replace? Maui Jim S-Series Tech 40 05-04-2011 09:46 PM
Daughter's 2005 Ion Emission Code timb99 Ion Tech 6 08-08-2008 09:08 AM
P0601 code, what causes it? s-seriesguy Ion Tech 1 03-14-2008 12:20 AM
