Old 08-26-2014, 12:06 PM   #1
SilverSpectre
SilverSpectre is on a distinguished road
SilverSpectre's Avatar
2007 ION-3 Quad Coupe
2006 VUE 2.2L
Default Rear Brake Swap with SC2
Hello all.
I have been doing some research into putting rear disc brakes on my 07 Ion 3. My goal is to do it without switching to a 5 lug hub or getting 17 inch wheels.
It was suggested in an old thread that using the calipers, brackets, pads and rotors from an SC 2 could accomplish this goal. If this is true, how exactly would I go about installing the calipers and housing brackets themselves?
Many thanks in advance for your thoughts.
2007 Saturn Ion 3 QC - "The Silver Spectre"
Resurrected 12/29/11
OZ Allegerita Wheels, FE5 Suspension w/ adjustable end links, Eibach Pro Kit, Progress Rear Sway Bar, TWM Short Shifter
Add to SilverSpectre's Reputation
Rate the quality of this post and help SilverSpectre reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SilverSpectre is offline   Reply With Quote
Old 08-26-2014, 12:13 PM   #2
kevin.st56
kevin.st56 has a spectacular aura aboutkevin.st56 has a spectacular aura about
kevin.st56's Avatar
2003 ION-2 Sedan
Default Re: Rear Brake Swap with SC2
i have great interest in this. youd have to see how well everything lines up, and whether or not a rotor can be placed on the rear hubs.
03 ion-2 Sedan 5sp
94 Honda civic automatic "VTEC yo"
05 Santa Fe 2.7L (Fefe) {Wrecked}
"A problem clearly stated, is a problem half solved."
♕KCCO
Add to kevin.st56's Reputation
Rate the quality of this post and help kevin.st56 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kevin.st56 is offline   Reply With Quote
Old 08-26-2014, 12:56 PM   #3
SilverSpectre
2006 VUE 2.2L
From what I understand, the rotors will fit. The rotors for the SC, just like the ion have a 4 x100 bolt pattern.
My main concern is how the caliper housing bracket will a fix to the axle.
Old 08-26-2014, 09:39 PM   #4
2006 ion2
2007 ION-2 Sedan
Especially with the rear suspension being a completely different setup...
2007 Saturn Ion 2
2003 Chevrolet venture lt
Add to 2006 ion2's Reputation
Old 08-26-2014, 09:49 PM   #5
SilverSpectre
2006 VUE 2.2L
I know. I wouldn't even be considering this if I hadn't seen it suggested by another master member.
Old 08-26-2014, 10:00 PM   #6
SilverSpectre
2006 VUE 2.2L
Here is what saturn69 said:
"High performance front rotors and pads and rear shoes would be cheaper and more effective, as the propotioning valve on the Ion is not set up for rear discs. I still think a cheaper, easier way would be to use the S-series rear discs, calipers and parking brake mechanism..."
Old 08-27-2014, 01:25 PM   #7
kevin.st56
kevin.st56's Avatar
2003 ION-2 Sedan
if need be, i can spend a day at pull apart and try to match the system. best place to try, as long as everything on both cars are there, and if both cars are on the lot. the nearest one from me does not have an SC2 unfortunately, but has 2 ions added within the last week
03 ion-2 Sedan 5sp
♕KCCO
Old 08-27-2014, 02:41 PM   #8
SilverSpectre
2006 VUE 2.2L
that would be fantastic! please keep me posted. I will see if I can track down an SC to pull apart, and see what I can do with that.
I really wish we could get in contact with Saturn69 and see what he meant exactly when he suggested this idea. I did send him a personal message, but he never responded.
Old 08-27-2014, 04:17 PM   #9
kevin.st56
kevin.st56's Avatar
2003 ION-2 Sedan
there is another pullapart thats about an hour and a half away, but i dont think imma make that drive.
the only big concern whether if itll fit or not is seeing if there is any way of getting mounts for the caliper on the rear end. i was thinking wheel hubs, but they are almost identical. same mounting bolt position, but the ions have a wider gap between the mounts and the wheel studs. ill look at diagrams further to see if i see anything.
03 ion-2 Sedan 5sp
♕KCCO
Old 08-27-2014, 10:41 PM   #10
ssicarman
ssicarman's Avatar
Can't be done plug and play.
The ION does not have the mount points for the rear caliper bracket that the S-series does.
You would be looking at a lot of custom fabrication.
Add to ssicarman's Reputation
Old 08-27-2014, 11:57 PM   #11
ruley73
ruley73's Avatar
2007 ION-2 Quad Coupe
^^^ +1,000
This thread has epic fail written all over it.
2007 Ion 2 Quad Coupe 5-speed manual 178K miles
2007 Chevy Equinox LT 187K miles
Add to ruley73's Reputation
Old 08-28-2014, 07:24 AM   #12
SilverSpectre
2006 VUE 2.2L
QUOTE=ssicarman;2089227]Can't be done plug and play.
You would be looking at a lot of custom fabrication.[/QUOTE]
I had a feeling this would be the case. I have no fear of doing some fabrication.
My hypothesis is that once you weld in mounting points for the caliper housing bracket, everything else will fit into place the way its supposed to. Of course the key would be to make sure that the mounting points are set in the correct place.
How is this idea any different from making a smaller version of the kit SSBC or Powell made? Their kits are using the same principal, you have to create a mounting point for the caliper housing bracket. However, both companies say that you need to have a 17 inch wheels. The SC did not have 17 inch wheels, and yet had disc brakes in the rear with a 4 by 100 wheel bolt pattern. See where I'm going?
Old 08-28-2014, 08:30 AM   #13
ruley73
ruley73's Avatar
How is this idea any different from making a smaller version of the kit SSBC or Powell made? Their kits are using the same principal, you have to create a mounting point for the caliper housing bracket. However, both companies say that you need to have a 17 inch wheels. The SC did not have 17 inch wheels, and yet had disc brakes in the rear with a 4 by 100 wheel bolt pattern. See where I'm going?[/QUOTE]
With the exception of the hubs & rotors, the kits were probably just Red Line parts. Hence the need for 17-inch wheels.
Old 08-28-2014, 10:42 AM   #14
SilverSpectre
2006 VUE 2.2L
With the exception of the hubs & rotors, the kits were probably just Red Line parts. Hence the need for 17-inch wheels.[/QUOTE]
Let me pose this question then: does anyone know how the SSBC kit (or any other rear disc conversion kit for the ion) connects the caliper housing bracket to the rear axle? The answer to this question may give me what I need to make this happen.
Old 08-28-2014, 12:12 PM   #15
kevin.st56
kevin.st56's Avatar
2003 ION-2 Sedan
why not look into a redline axel beam?
why try and build one, when you can look at one that came with disks, and compare fitment of the s-series to the RL frame?
03 ion-2 Sedan 5sp
♕KCCO
Old 08-28-2014, 01:11 PM   #16
SilverSpectre
2006 VUE 2.2L
that is a good point. I think I will try that, however yes my concern would be over the fitment of those calipers. see what you can find out on your end as well.
Old 08-28-2014, 02:58 PM   #17
kevin.st56
kevin.st56's Avatar
2003 ION-2 Sedan
im just concerned about how the RL calipers are mounted VS the s-series. if i can actually see how they are setup, and see it on a parts diagram, then it be easier. it be even better if i had a RL and an s-series to look at personally. i dont think PAP has any s-series that are nearby. ill keep searching.
03 ion-2 Sedan 5sp
♕KCCO
Old 08-29-2014, 12:52 AM   #18
ruley73
ruley73's Avatar
Some of the previous posts might be a bit confusing because a bit of the code was missing in SilverSpectre's reply to ssicarman's quote to so it wasn't being formatted correctly. The missing code then messed up my response when I wanted to quote SilverSpectre. This is how my response to SilverSpectre (and SilverSpectre's response to ssicarman) should have looked.
Old 09-01-2014, 09:32 AM   #19
SilverSpectre
2006 VUE 2.2L
Specs time
SC Rotors:
Outer Diameter - 9.64 inches
Height - 1.63 inches
Thickness - 0.435 inch
Redline Rotors:
Outer Diameter - 10.63 inches
Height - 1.77 inches
Thickness - 0.551 inch
As I suspected, the Redline rotors are slightly bigger. Therefore, using the Redline calipers with the SC rotors probably would not work.
I can't yet confirm if the caliper housing bracket from the SC would fit in the mounting points for the Redline axle. If it does, this could work with little to no modification required.
However, I believe I have an idea to modify the existing mount points on the Redline axle to accommodate the SC calipers if needed. I will keep you posted on my progress.
Old 09-02-2014, 12:38 PM   #20
kevin.st56
kevin.st56's Avatar
2003 ION-2 Sedan
if we were to use the SC rotors, all you would need to do is make sure SC calipers would fit, and hope that the RL mounts dont make the calipers too far to the outside edge of the rotor, or too close too the hub. the next thing would be brake lines, but lets not go there untill we confirm fitment of calipers.
Edit: just done a search on a nearby pull apart, and there is a ton of S-series, newest being 2001, but not SC's. i cant tell if there are any RLs bec most of the time, theyll put all submodels (sedan, QC, RL) under one model (ion), so the only way for me to tell if there is a RL or not, is to go there. i will be taking a trip there this weekend.
03 ion-2 Sedan 5sp
♕KCCO
Rear disc brake swap parts Moskvitch S-Series Tech 5 11-08-2013 01:46 PM
98 sl2 rear disk brake cable for drum to disk swap JungleKing07 S-Series Mods 3 09-13-2012 02:02 AM
3rd Gen brake bleed problems after rear disc swap SL1Guy S-Series Tech 9 09-11-2010 06:53 PM
2nd Gen Rear Disc Brake Swap: 1st gen brakes fit? TIMSPEED S-Series Tech 4 02-19-2008 12:06 AM
Rear Brake noise after brake job kim_lombard S-Series General 5 04-22-2007 10:40 PM
