Old 05-25-2014, 01:30 AM   #1
korado665
korado665 has a spectacular aura aboutkorado665 has a spectacular aura about
Default Gen 3 2002 SC2 Instrument Cluster Connector Wiring Help
Hi guys. I need some help with my Gen 3 2002 Saturn SC2. After having success with the IPJB A2 (F5) issue, I had the confidence to take on another electrical issue. My instrument cluster was acting up... back lights and opera lights flickering and going off, turn signals indicators working when they feel like it, etc. When I notices that things go on and off when I wiggle the harness by the connector, i decided to retension those tiny GM Micro-pack terminals. Normally I take pictures of everything before I start, but this time I figured if I go one pin at a time, I won't need pictures. Well... I must have reinstalled a terminal into the wrong position. The cluster is basically dead except for the security light.
Would anyone out there be kind enough to provide me with a pin-out chart or close-up pictures of their instrument cluster wiring harness so I could get the right colors in the right sockets?
Add to korado665's Reputation
Rate the quality of this post and help korado665 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
korado665 is offline   Reply With Quote
Old 05-25-2014, 03:25 AM   #2
Default Re: Gen 3 2002 SC2 Instrument Cluster Connector Wiring Help
Does this help?
Old 05-25-2014, 03:49 PM   #3
korado665
This is awesome. Just what I was looking for. Printing this out and heading to my car right now. YOU ARE THE MAN!!! Thank you. Remember the fallen.
Old 05-27-2014, 08:14 AM   #4
korado665
Thanks to the diagram, I found my problem. I inserted the pin that should have been in A1 into B1. Cluster works again. All's good in saturnville. Thanks again.
Old 05-27-2014, 08:20 AM   #5
The best part is that YOU found and fixed the problem! Thank you for posting a follow up.
Old 06-23-2014, 08:26 AM   #6
Freak Storm
Freak Storm is on a distinguished road
2002 SL1
I've been having instument cluster problems ever since I replaced the dash bulbs. I'm fairly certain that retensioning the electrical pins in the harness pack will solve the problem. How should I go about this?
Is there a way to retension without pulling each pin out? Thanks!
Add to Freak Storm's Reputation
Rate the quality of this post and help Freak Storm reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Freak Storm is offline   Reply With Quote
Old 06-23-2014, 11:18 AM   #7
There are male pins and female sockets. Sometimes when reconnecting connections, pins or sockets fail to align and push against each other resulting in pushing out either pin or socket. A careful visual inspection can sometimes reveal which terminal pushed out by how much wire is displaced in a bundle or if a terminal peeks out behind the plastic connector before disconnecting things.
Old 06-23-2014, 07:16 PM   #8
Freak Storm
2002 SL1
Thanks, I'll check it out.
I'm mainly trying to figure out the best way to retension the pins. Thanks for your input.
2002 instrument cluster bulb part no se4587 S-Series General 15 11-16-2013 08:58 AM
2006 Vue Instrument Cluster on 2002 SL1 2002SATURN-PHX S-Series Mods 2 06-17-2013 09:37 AM
Wiring diagram for 06+ instrument cluster? ssewall Vue Tech 1 12-08-2011 10:26 AM
What LEDs do I need for 2002 SC2 instrument cluster? bigtoque S-Series General 16 09-22-2008 03:56 PM
Help figuring out the wiring scheme of the Instrument Cluster Terrandus S-Series Tech 14 03-11-2003 10:38 AM
