Old 06-13-2014, 02:48 PM   #1
Cookbenj
Cookbenj is on a distinguished road
Default Sc1 2001 aftermarket Stereo problems
i am having a problem installing an after market radio xdm260 I've done the wiring etc.. but it doesn't seem to work, the back part of the radio has a flashing red light which indicates its on.
But the front part of the radio (the interface) does not work.
i don't know why, i connect the wiring and i hear the speakers make a synchronising sound but nothing else and i don't see a display.
I've uploaded the wiring i did please help me to see if i messed up anything.
Also the 4 wires on the harness i didn't know what to do because there were no wire for me to connect them with, also the very last picture shows this metal kind of wire and i don't know what to do with it since i couldn't see any connection for the back part of the stereo
Any help will be really appreciated since i do miss having music in my saturn
Thanks
Add to Cookbenj's Reputation
Rate the quality of this post and help Cookbenj reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Cookbenj is offline   Reply With Quote
Old 06-13-2014, 04:51 PM   #2
Default Re: Sc1 2001 aftermarket Stereo problems
That's a ground wire. Easiest thing to do is replace that spade end with a loop end and pick any of the screws on the frame to attach it to. Might be the reason it's not turning on, it's not fully grounded.
Should be good for '00-'02 S-Series:
Old 06-13-2014, 07:48 PM   #3
Cookbenj
Thanks for the info, it turns out I already have the ground wire wired in the car. Still no luck
Old 06-13-2014, 11:47 PM   #4
Cookbenj
so the best option is to just take it to a radio shop since they are the experts, i just waned a little project on my hands since I've had a lot of spare time, but it turns everything i did was correct it was the acc module which didn't have a wire but the store sorted something out, and then i finished the installation so I'm happy now but i appreciate your help
Aftermarket stereo trckey2 S-Series General 25 08-29-2014 11:55 PM
Aftermarket stereo, what is VX MMi? silvertoy Astra General 20 07-22-2009 05:34 PM
Anyone with Aftermarket Stereo's? nitsua196 Aura General 0 04-14-2007 12:27 AM
94 SC aftermarket stereo roblun S-Series General 3 04-10-2007 09:49 PM
help with aftermarket stereo defy69 Ion General 25 03-05-2005 04:41 AM
