Old 03-06-2014, 02:02 PM   #61
sallydriver
sallydriver is a name known to allsallydriver is a name known to allsallydriver is a name known to allsallydriver is a name known to allsallydriver is a name known to allsallydriver is a name known to all
sallydriver's Avatar
1993 SW2
Default Re: Questions about Partial Rebuild
Well, my iPad has been out of commision, but if you want updates on the car, then go here:
http://www.twogearheadsracing.com
The site's coding isn't perfect, as I'm teaching myself HTML to run it. It's definitely a work in progress.
2014 Cannondale 27spd 29": 30 miles
1999 Forest Green SL2 5spd "Sally" 5spd : 307,100+ miles
1993 White SW2 5spd "Steve" 5spd : 234,984 miles
Add to sallydriver's Reputation
Rate the quality of this post and help sallydriver reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sallydriver is offline   Reply With Quote
Old 03-08-2014, 01:45 PM   #62
sallydriver
1993 SW2
OK, so I finally got some Loctite 515 via Amazon. It's a really small tube. Will it be enough for the whole tranny?
Old 03-08-2014, 01:54 PM   #63
You lay down a continuous thin thread all the way around that flange, circle the 5 bolt holes around the differential and inside of all other bolt holes. Center the bead 1-3mm wide on the mating flange. What size tube did you order?
Old 03-08-2014, 02:13 PM   #64
sallydriver
1993 SW2
.2 ounces
Old 03-08-2014, 08:49 PM   #65
Is that 6ml?, should be. Probably enough as it is thin and watery and the bead only has to be 1 to 3 mm wide and 1mm is plenty.
1 mm = 0.039" or 1/25th inch
Old 03-08-2014, 08:54 PM   #66
sallydriver
1993 SW2
Oh... OK.
Do I use it on the fifth gear cover also? Or can that be RTV?
Old 03-08-2014, 09:13 PM   #67
anmasher
anmasher has a spectacular aura aboutanmasher has a spectacular aura aboutanmasher has a spectacular aura about
anmasher's Avatar
1996 SL2
Preferably you use the actual gasket there. RTV works too.
So.... what happens when you seal the case halves with RTV?
Add to anmasher's Reputation
Rate the quality of this post and help anmasher reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
anmasher is offline   Reply With Quote
Old 03-08-2014, 11:17 PM   #68
It is too thick and you have clearance problems, just like you will have if you use RTV on the 5th gear cover. Get the correct gasket or make one out of a grocery bag and very thinly coat both sides with RTV so it does not leak/seep. Spread the RTV with a razor blade and you want to be able to see through it. Cut gasket with a ball pein hammer.
The 515 will make a 0.001 to 0.002 thick seal between those flanges, that is why you do not need much. Don't try and make a round bead with it just hold tube near vertical and lay down that single thin bead tip wide and very thin.
Old 03-26-2014, 02:25 AM   #69
sallydriver
1993 SW2
Thanks. Oh, FYI, differential bearings ARE available on RockAuto.
Old 03-26-2014, 06:55 AM   #70
Lots of things are available at the FLAPS. When it comes to bearings that are very difficult to replace I tend to go to a quality bearing suppler and go with the high quality - high dollar bearing.
Old 05-22-2014, 05:21 AM   #71
sallydriver
1993 SW2
Hey everyone, sorry about the lack of updates! Been in school, and now am currently looking for a new job, as my current workplace is closing in 9 days.
Will be hopefully tearing into the car soon.
Rebuild Questions, v2.0 Spaghettiohead S-Series Tech 2 09-11-2013 09:35 PM
rebuild issues...a few questions Diezeltitan08 S-Series Tech 13 07-07-2011 06:27 PM
deebs rebuild questions Diezeltitan08 S-Series Mods 3 12-04-2010 08:29 PM
Rebuild questions triple_el S-Series Tech 24 08-15-2008 04:23 AM
Rebuild Questions Cincyperf S-Series Tech 3 09-12-2007 08:53 AM
