Old 03-28-2014, 01:42 PM   #1
Fermium
Fermium is on a distinguished road
Default SL2 99 check engine light On and OFF
The link below is my previous post that (I think) might related to this problem.
(Won't let me post a link...my post is in this forum with title: SL2 99 check engine light comes code P1404 and P1599)
Couple months ago, my enginer light went on with P1404 so I changed my EGR valve. The engine light went off for a couple of days. Then it went on again for couple of weeks. Then switched off again and yesterday it went on again.
I took the car to the "auto-store" to check my engine light, the person told me there's no code. She suggested maybe my car needs oil change? (It's almost 3500 miles since my last oil change)
So with my new EGR valve (It's the 2nd EGR valve within a year because the P1404 code came on last year so I've already changed the EGR valve once) What do you guys think its the problem?
P.S. I can go check the engine light again to see if there's any new code...
Add to Fermium's Reputation
Rate the quality of this post and help Fermium reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Fermium is offline   Reply With Quote
Old 03-28-2014, 02:42 PM   #2
Signmaster
Signmaster is a name known to allSignmaster is a name known to allSignmaster is a name known to allSignmaster is a name known to allSignmaster is a name known to allSignmaster is a name known to all
Default Re: SL2 99 check engine light On and OFF
Intermittent faults can clear on their own over time, usually based on key on/off or drive cycles. If the EGR malfunctions some times, but not all the time, you have a limited time frame to check it out before the code will clear.
There are also times when the light will come on, but not set a code. I'm not sure if this is a time thing (as in the light must come on for X seconds), or just the nature of some code storing scheme on certain items.
stuck in park, check engine light, brake light flashing Wemble Ion General 8 02-08-2014 04:38 PM
What is Saturn's equivalent of "Check engine light"? Smog won't pass bulb check. harmono S-Series General 5 02-28-2012 10:17 AM
check engine light and coolant level light stuck on saturn/chev S-Series General 13 11-22-2011 08:20 PM
check engine light and antitheft light 2004 L300 jonus311 L-Series Tech 2 01-31-2009 08:55 AM
Check Engine Light W/ Reduced Power light saturnfreak01 L-Series Tech 5 01-24-2004 11:04 PM
