Old 02-02-2014, 03:50 PM   #1
thejoy
thejoy is on a distinguished road
Default outlook 2008:no heat in back seat
Brand new member !
just bought a used 2008 outlook.
Just cant seem to get hot air in the rear. Hot air is coming out of driver and passenger side. All rear air vents are only blowing cold air. Even if I press the AUX button or play with the rear settings, I never get hot air in the back.
Is there something I am doing wrong ( hope so ! ) ?
thanks for any info on this.
Add to thejoy's Reputation
Rate the quality of this post and help thejoy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
thejoy is offline   Reply With Quote
Old 02-04-2014, 11:05 AM   #2
Default Re: outlook 2008:no heat in back seat
Not being familiar with Outlooks, my only contribution would be relating my knowledge of my L300 sedan heating system to yours. Mine has two floor vents for rear passengers to channel heated air from the HVAC system. If you have your owner's manual, review any instructions about rear heat/cold settings and any drawings depicting HVAC air flow. If you're lucky, this may be just a blown fuse to the auxiliary blower?
Old 02-04-2014, 11:48 AM   #3
satlite440
satlite440 has much to be proud ofsatlite440 has much to be proud ofsatlite440 has much to be proud ofsatlite440 has much to be proud ofsatlite440 has much to be proud ofsatlite440 has much to be proud ofsatlite440 has much to be proud ofsatlite440 has much to be proud of
2001 SL2
with out being able to see rear havc data.. at the pass rear corner underneath you will see the a/c&heater core pipes after you have driven about 10 miles or so see if both pipes are hot.. if they are suspect a hvac mode door actuator.. if not hot ck coolant level..
shure you can trust the government,just ask us indians all about it...
heavy line the final protective fire line of the dealership
Add to satlite440's Reputation
Rate the quality of this post and help satlite440 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
satlite440 is offline   Reply With Quote
2003 VUE Rear Seat Belt Stuck ... Back Seat Won't Fold Up burnsej Vue General 5 08-28-2016 10:05 PM
No heat in back TommyK Relay Tech 4 10-04-2013 01:47 PM
2008 Vue XR AC/Heat Issues Sam McGowan Vue Tech 8 11-29-2011 06:11 PM
2008 Saturn Vue XR FWD low heat ETruss60 Vue Tech 3 01-11-2011 10:17 AM
Outlook back seat debates Outlook General 6 01-09-2007 04:35 PM
