Old 01-15-2014, 12:39 AM   #1
Hutchptx
Hutchptx is on a distinguished road
Default 99 SL2 Races after putitng in park/neutral
Hey Guys. Ive followed for a while, and been looking for similar issues.
Ive got a 99 SL2 DOHC with 210K on it. Ive had issues for a while and have most of them cleared up - IAC issues (replaced), dirty TB, etc. Whats going on now is (1) if I come to a stop and and still in gear (Automatic) the idle drops, and gets rough, sometimes stalls. If I come to a stop and put it in park or neutral, the RPM surges to about 2-2.5K RPM before setting back down to about 900. If i turn it off, let it sit for a bit and start it back up, i get the same high RPM burst before settling down to a 900RPM idle. I had the guy who did a state inspection check it for codes and he pulled a P0410B - Air Injector Reactor Management.
Homework again said this could be part of the secondary air pump, the valve for it, or a vacuum leak. I'll be looking at that this weekend, but wanted to see if any of you had run across this code or problem, and what you did to fix it.
Add to Hutchptx's Reputation
Rate the quality of this post and help Hutchptx reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Hutchptx is offline   Reply With Quote
Old 01-15-2014, 05:57 AM   #2
Signmaster
Default Re: 99 SL2 Races after putitng in park/neutral
http://www.youtube.com/watch?v=dIrmkxj6wJE
This video breaks down the common problems with the system. Carbon deposits in the tubes are common, as well as in the exhaust manifold.
Save that channel as well, he has a lot of good S Series videos and is a member here on the forums.
Old 01-15-2014, 09:32 AM   #3
BV22
BV22 is a glorious beacon of lightBV22 is a glorious beacon of lightBV22 is a glorious beacon of lightBV22 is a glorious beacon of lightBV22 is a glorious beacon of light
2002 SC1
Not sure what the "B" at the end of the code means, but P0410 does indeed relate to the secondary air injection system. It may or may not be related to your wild idle condition. High idle is usually because of a failing TPS or a vacuum leak. When the TPS is failing, a restart typically makes the idle return to normal until the gas pedal is pressed again. There is a small vacuum line from the top of the throttle body that runs to the little solenoid valve on top of the a/c compressor. This line provides vacuum to the diverter valve to allow air from the air pump into the exhaust stream on cold starts. If this line is compromised, it could lead to high idle and P0410.
BV22
2002 SC1 5M
313k 07/18
Add to BV22's Reputation
Old 01-16-2014, 01:27 AM   #4
Hutchptx
I'll have to check this weekend for the vacuum leak. Good to know and thanks for the tip. I took it for a long drive today and noticed something else. My temp gauge never cleared the 1/4 mark even after an hours driving. Had plenty of heat. Some im wondering if the ECTS may be partly at fault here too causing it to run rich, and hitting the high idle coming out of gear and bogging down when sitting still in gear. I think I'm going to shoot to replace that this weekend as well if the snow isnt too bad.
Old 01-16-2014, 06:34 AM   #5
Signmaster
Any time you have a high idle the ECTS and/or thermostat can be contributing factors. If your ECTS isn't working it can run rich as you suspected, and since a working ECTS deals with coolant temps, the faulty thermostat can force the car to run rich as well.
Being the twin cam cars generally hold temp better even when it's cold and the heater is in use, one or both are probably suspect. Neither will normally cause the idle RPM to be up in the 2-2.5K range mentioned with your first concern and the code though, so I'd follow through on that as well.
04 Vue won't go above 2500 rpm even in park and neutral jtmauser98 Vue Tech 11 04-29-2013 12:49 AM
'98 SL1 - Engine races at idle, but only in park Zaphod S-Series General 1 02-06-2012 01:30 PM
Diff pin went, put JY transmission in, only have park and neutral Bealson Wheels S-Series Tech 21 03-19-2011 03:07 PM
High idle in park and neutral blakerybob03 S-Series Tech 4 03-03-2011 08:50 PM
rough idle in park or neutral... mlc5 Vue Tech 16 12-12-2009 06:13 PM
