Go Back Forums > Models > Saturn L-Series > L-Series Tech
Old 01-04-2014, 12:21 PM   #21
hacadacalopolis is on a distinguished road
hacadacalopolis's Avatar
2003 L-Series 2.2L Sedan
1996 SC1
Default Re: Broken exhaust manifold! not cracked, completely sheared off!
For common gray
You have to overcome the problem that there is a 50/50 chance of it holding under heat/pressure load.
The grain structure of the casting (microscoply) can have voids and pockets of porosity- so what does that do when your welding... Same exact thing porosity.
Even with your proper preheat and post heat instructions
Most of you probably already know this but if not. Many cast irons can be welded with success, but as in this case with an exhaust manifold in almost every situation as the exhaust mani(with welded repair) will cool after use and eventually crack. Not all cases but it is most likely to happen. This is true
That is why a welder may refuse to qualify welding cast iron subject to such amounts of heat.
Add to hacadacalopolis's Reputation
Rate the quality of this post and help hacadacalopolis reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hacadacalopolis is offline   Reply With Quote Sponsored Links
Exhaust completely cracked. zero_cool09 S-Series Tech 11 03-23-2012 10:58 PM
Broken exhaust manifold stud JohnS_98 S-Series Tech 2 06-10-2011 04:07 PM
Cracked exhaust manifold saturfly L-Series Tech 3 03-02-2007 09:01 PM
2001 L200 atx exhaust manifold cracked btrautman L-Series Tech 13 05-03-2005 02:59 PM
Cracked exhaust manifold btrautman L-Series General 0 04-07-2005 10:33 PM
Copyright ©2000 - 2018, vBulletin Solutions, Inc. The Saturn Enthusiasts Site.
