Old 09-19-2013, 12:32 AM   #1
neisy66
neisy66 is on a distinguished road
Dizzy lighter burns out fuse
the lighter in my 95 sl keeps burning out the 20 amp fuse What is causing this?
Add to neisy66's Reputation
Rate the quality of this post and help neisy66 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
neisy66 is offline   Reply With Quote
Old 09-19-2013, 12:50 AM   #2
RobertGary1
1996 SC2
Default Re: lighter burns out fuse
Ever hear the story about the guy who goes to the Dr complaining that it hurt when he reached behind his head to scratch his back? The Dr replied 'then don't do that'. Just buy a lighter.
-Robert
Old 09-19-2013, 01:05 AM   #3
LabRat
LabRat is on a distinguished road
The fuse is burning out because the circuit is pulling more than 20 amps when you use it. The usual cause for this is a short somewhere. You can chase the short or don't use the lighter.
-LR
Add to LabRat's Reputation
Rate the quality of this post and help LabRat reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
LabRat is offline   Reply With Quote
Old 09-19-2013, 01:14 AM   #4
Replace your lighter element. If the fuse is opening because you are plugging something else into the socket then either the socket is bad or what you are connecting is overloading the system.
Old 09-19-2013, 03:09 AM   #5
Ranzear
Ranzear is on a distinguished road
Have you looked inside it yet?
Because dimes and pennies are the perfect size to short a cigarette lighter socket, but still let you plug something into it (or only short it when you do).
Add to Ranzear's Reputation
Rate the quality of this post and help Ranzear reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Ranzear is offline   Reply With Quote
Old 09-19-2013, 03:56 AM   #6
neisy66
yes I did check that first and the only thing I have plugged in is the lighter thanx for your reply
Old 09-19-2013, 04:55 AM   #7
GeekOnTheHill
GeekOnTheHill is a jewel in the roughGeekOnTheHill is a jewel in the roughGeekOnTheHill is a jewel in the roughGeekOnTheHill is a jewel in the rough
GeekOnTheHill's Avatar
If it only blows out when the lighter is pushed in (not an accessory), then probably the lighter element is shorted out.
If it blows out whenever you plug anything into it (like a cell phone charger), then most likely there's a short in the socket.
If it were a short in the wiring leading to the socket, then the fuse would blow as soon as the fuse was inserted, regardless of whether anything was inserted into the lighter socket.
-Richard
Add to GeekOnTheHill's Reputation
Rate the quality of this post and help GeekOnTheHill reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
GeekOnTheHill is offline   Reply With Quote
Old 09-19-2013, 05:45 AM   #8
neisy66
Dizzy Re: lighter burns out fuse
-Richard
very clear answer will check these and give results here later Thanx Geek
97 sl1 cigarette lighter fuse how to fix dddaaa S-Series Tech 11 01-01-2016 02:11 AM
1994 SL2 Lighter Fuse Help ronk L-Series Tech 2 02-20-2007 10:59 AM
cigarrete lighter fuse Saturn94SC1 S-Series Tech 4 01-07-2006 07:04 PM
Car Lighter Fuse sipherx698 S-Series General 1 05-05-2004 04:07 PM
cigarette lighter fuse sloppyo Miscellaneous Tech 3 10-13-2003 07:01 AM
