Old 08-20-2013, 04:39 PM   #1
aficio
aficio is on a distinguished road
Default Limp mode or not
My1997 1.9 sohc sl1 automatic, has around 190k on it and is sometimes not accelerating like it should from a stop. when I start and press on the accelerator it will just not bring up the rpm and I have to take my foot off on the pedal and let the motor catch up once it does it is fine I can put it to the floor and it will take off and drive as normal it does not do this every time but it does at least once or twice a day. I disconnected the EGR valve connector and it is running fine.
1. by disconnecting the egr and having the SES light come on did that put the car in limp mode?
I have already put in a new brass temp sensor and the map is only about a year old.
if it does not put it into limp mode then I should be able to replace it and be okay if it does then I will need to test all of the inputs to the ECU.
Thanks for reading
Add to aficio's Reputation
Rate the quality of this post and help aficio reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
aficio is offline   Reply With Quote
Old 08-20-2013, 04:45 PM   #2
Default Re: Limp mode or not
Your SL1 isn't an L-series car and does not have any form of limp home mode. Repost again but in the S-series tech forum for more help there.
Limp Mode proveniebam S-Series Tech 1 06-20-2013 03:23 PM
Car going into limp mode?? Setapart22 Ion General 14 03-07-2012 01:59 PM
LIMP MODE ( oh great ! ) jaman Ion General 9 08-25-2008 09:48 PM
Limp Mode kdb176 Ion Red Line 11 02-08-2008 07:51 AM
EGR P1404 and Limp Mode CapeDude S-Series Tech 3 08-10-2006 10:43 PM
