Old 08-19-2013, 01:49 PM   #1
SC2driver2002
SC2driver2002 is on a distinguished road
Default My check engine light came on and got 6 different codes... Please help
My car has had 6 different codes thrown the codes are as follows:
P0442,P0128,P0327,P0341,P0410,P1620
I have looked up all these codes and know what they mean. I know I will need to change the thermostat since two different codes pointed to that, but what I don't know what to do is how to check if the PCM is messed up since that is a possibility from one of these codes. The car runs perfectly fine I have not noticed and change in performance or acceleration and the temp gauge reads normal. One thing I noticed is that the fuel economy has dipped recently probably because there is a small leak in the air pump. I guess what I really need help with is finding an air pump and the one way check valve and how to check if those are part of the problem. Is it possible that my PCM is just messed up in general and thats why its throwing the codes? Please help it would be very much so appreciated
Add to SC2driver2002's Reputation
Rate the quality of this post and help SC2driver2002 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SC2driver2002 is offline   Reply With Quote
Old 08-19-2013, 02:46 PM   #2
Default Re: My check engine light came on and got 6 different codes... Please help
Fix the thermostat, STANT 14279 not the MOTORAD that includes the outlet housing. Then change the plugs and wires to get rid of the 341. Pull the PCM B fuse and see what comes back. There will be a repeat offender.
This will get you started on the AIR system. http://www.youtube.com/watch?v=dIrmkxj6wJE Parts are best found at the J/Y except for the diverter valve and it is a bit expensive so a good one from the J/Y is worth a shot if it is clean.
Old 08-19-2013, 03:39 PM   #3
SC2driver2002
So change the spark plugs and wires you mean? I just want to be sure about what to change.
Old 08-19-2013, 04:21 PM   #4
BV22
BV22 is a glorious beacon of lightBV22 is a glorious beacon of lightBV22 is a glorious beacon of lightBV22 is a glorious beacon of lightBV22 is a glorious beacon of light
2002 SC1
Plugs and wires cause the P0341 code, so yes, replace them. Use the NGK copper plugs and a mid-priced, direct fit wire set. P0442 is usually gas cap related, and sometimes, just tightening the cap will fix the problem. I second the recommendation on the Richpin video for the air pump system. The system is not all that complicated, but the prices of the parts can add up if you start replacing things unnecessarily.
BV22
2002 SC1 5M
313k 07/18
Add to BV22's Reputation
BV22 is online now   Reply With Quote
Check Engine Light w/Codes Trey723 Vue Tech 2 09-15-2011 07:13 AM
Check engine light.....no codes. wth? vettegofast Vue Tech 8 07-08-2010 02:43 PM
check engine light, no codes? namato1 Vue Tech 9 03-01-2009 07:48 PM
Check Engine Light Codes cptcrnch S-Series Tech 4 09-22-2008 06:21 AM
HELP - check engine light.. codes 26 and 32 jrs87 S-Series Tech 7 08-07-2006 04:21 PM
