Old 04-30-2013, 07:06 PM   #1
sallydriver
sallydriver is a name known to allsallydriver is a name known to allsallydriver is a name known to allsallydriver is a name known to allsallydriver is a name known to allsallydriver is a name known to all
sallydriver's Avatar
1993 SW2
Default What Trailer Wiring?
Hey forums! Just wondering, what wiring kit would be best used with my '99 SL2? Or, can I fabricate one for cheaper?
FYI my taillights are LED, and I'm wanting all lights to be LED eventually.
(Don't worry, I'll only be towing a 6ft. trailer with a small go-kart.)
1998 Red SL 5spd "The Right Honorable Duke Farnsworth the Functional of Clearfield":165,000 miles
1999 Forest Green SL2 5spd "Sally": 307,100+ miles
1993 White SW2 5spd "Steve": 234,984 miles
Add to sallydriver's Reputation
Rate the quality of this post and help sallydriver reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sallydriver is offline   Reply With Quote
Old 04-30-2013, 07:41 PM   #2
wb 86
wb 86 is on a distinguished road
wb 86's Avatar
1999 SL
Default Re: What Trailer Wiring?
I use this one http://www.etrailer.com/Custom-Fit-V...id=19991175778. Haven't tried it with LEDs though.
-Craig
1999 SL
1995 Ford F250 PSD
Add to wb 86's Reputation
Rate the quality of this post and help wb 86 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
wb 86 is offline   Reply With Quote
Old 04-30-2013, 07:43 PM   #3
sallydriver
1993 SW2
What effect, if any, would LEDs have? Obviously their resistance is lower.
Old 05-01-2013, 03:59 PM   #4
sallydriver
1993 SW2
I went ahead and emailed etrailer.com my question. Will post response here.
Old 05-01-2013, 04:43 PM   #5
madpogue
1996 SW2
^^^^ Curt is generally good quality. Except don't use those dreadful scotch-lock things. Cut (or strip), splice, solder and heat-shrink. Most other cars, they make a "tee" harness, that plugs in wherever the vehicle's rear light harness plugs in, then the rear harness plugs into the tee, so there's no wire cutting/splicing/soldering, and none of those scotch-locks. Alas, I've never found one for our cars, most likely because there are two separate harness connectors, for the left and right rear lighting, and you'd have to tee into both. So they usu. point you to a generic setup like the above.
Add to madpogue's Reputation
Old 05-01-2013, 05:43 PM   #6
sallydriver
1993 SW2
I was definitely planning on soldering and using heat-shrink. My main question is whether LEDs in trailer and/or car lighting would affect the operation of this device.
Old 05-02-2013, 03:19 PM   #7
sallydriver
1993 SW2
Decided to just order the harness and install it.
Old 05-02-2013, 03:28 PM   #8
AlexofNazareth
AlexofNazareth will become famous soon enough
AlexofNazareth's Avatar
2002 SL1
Why would you think LED's create any difference over stock bulbs when splicing in trailer wires into your harness? They'll draw less power, otherwise everything is business as usual.
'02 SL1.414213562^2, Deebs ftw
Add to AlexofNazareth's Reputation
Rate the quality of this post and help AlexofNazareth reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
AlexofNazareth is offline   Reply With Quote
Old 05-02-2013, 03:29 PM   #9
sallydriver
1993 SW2
That's what I thought, I just wanted to make sure.
Trailer Wiring markwi77 L-Series Tech 0 03-24-2012 12:10 PM
Trailer Wiring 97 SW2 JimJ S-Series General 6 08-05-2008 09:59 AM
Trailer wiring, Hook-up of Battery Feed and Trailer Brake Fuses. 4myoutlook Outlook General 3 03-10-2008 07:45 AM
help with trailer wiring hawgwild Ion General 6 04-10-2007 01:32 PM
2001 SC2 wiring diagram? (trailer wiring harness) gumpish S-Series General 1 04-30-2005 11:45 PM
