Old 12-14-2012, 03:03 PM   #1
ninetynineSC2
ninetynineSC2 has a spectacular aura aboutninetynineSC2 has a spectacular aura aboutninetynineSC2 has a spectacular aura about
ninetynineSC2's Avatar
1999 SC2
Default Wiring question?
Is it possible to tap into the ignition switched 12V constant wire on the radio in order to wire in some LED lights under the dashboard? Or would it also work to get the power from the 12V wire to the cigarette outlet?
Current:
1999 SC2, 186,XXX
Past:
1989 Mustang LX, Unknown mileage(JY engine in it when I got it)
Add to ninetynineSC2's Reputation
Rate the quality of this post and help ninetynineSC2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ninetynineSC2 is offline   Reply With Quote
Old 12-14-2012, 03:13 PM   #2
ninetynineSC2
1999 SC2
Default Re: Wiring question?
I also read about a big pink wire that is below the dash...Would that work and what does that wire power?
Current:
1999 SC2, 186,XXX
Past:
Old 12-14-2012, 03:18 PM   #3
I don't know that this one doesn't come with a cover, but the one I got from eBay came with a plastic cover: http://www.autozone.com/autozone/acc...ier=32322_0_0_
Run a 16g or 14g wire directly from the battery power to the fuse panel, then add fuse's in for the circuit's you want. Should add a fuse to the wire as well, within ~6in of the battery cable.
By nearly all accounts it's a bad idea to add any load beyond stock to the stock wiring, and as things age they get brittle making it even more of a bad idea.
If you only plan on wiring in lights you can use this to power it and tap the switching leg of the relay into the stock switched +12v with no problems: http://www.summitracing.com/parts/FLX-31146 (I say only lights because most aftermarket radio's plus other loads would be higher then that particular relay is rated for)
Old 12-14-2012, 03:26 PM   #4
ninetynineSC2
1999 SC2
Awesome. Thanks....Dumb question, what would be the easiest way to get the wire from the battery to inside the car? I'm glad you mentioned not putting any additional load on the stock wires. My original plan was to simply ground the ground wire on the light and splice the power wire into the switched 12V
Current:
1999 SC2, 186,XXX
Past:
Old 12-14-2012, 03:58 PM   #5
Untwist/bend one of those old metal wire style coat hangers & carefully shove it through the rubber grommet next to where the main harness goes through, depending on the size/type of wire you run from the battery you may have to tape it to the wire to pull it through. Cutting a small hole in the grommet before shoving the coat hanger in would make the process much easier, or grinding a point onto the hanger
Wiring Question KellysVue Vue General 0 06-28-2006 02:57 PM
Wiring an Amp Question jdog L-Series General 5 09-27-2005 08:00 PM
Wiring Question OvenRude Mods and Performance 3 06-04-2003 03:33 PM
wiring question Tmac Miscellaneous Tech 4 10-13-2002 09:59 PM
another wiring question grumpy Mods and Performance 0 01-11-2002 04:07 AM
