Old 12-13-2012, 12:31 AM   #1
ninetynineSC2
ninetynineSC2 has a spectacular aura aboutninetynineSC2 has a spectacular aura aboutninetynineSC2 has a spectacular aura about
ninetynineSC2's Avatar
1999 SC2
Default T-Stat replacement question
I know theres dozens of threads on this but I like to be positive and doublecheck before I get anything for my car. Anyhow, the temp guage never really goes much past 1/4. I get air hot enough to cook me out of the car but the temp should be higher than that I feel a replacement T-Stat is better than paying more for potential problems later on. The Stant 14279 is the correct one right? Also, if the current T-Stat is bad would I see better fuel economy and such from replacing it? Thanks
Current:
1999 SC2, 186,XXX
Past:
1989 Mustang LX, Unknown mileage(JY engine in it when I got it)
Add to ninetynineSC2's Reputation
Rate the quality of this post and help ninetynineSC2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ninetynineSC2 is offline   Reply With Quote
Old 12-13-2012, 12:41 AM   #2
PurdueGuy
PurdueGuy's Avatar
1999 SC2
1999 SC1
Default Re: T-Stat replacement question
If it's going to 1/4, it's possible you have a good thermostat, but one that is made for the lower temp. The higher temp thermostat should help your fuel economy a bit.
To be sure, you've already replaced your ECTS, right?
SaturnSeries.net owner
Add to PurdueGuy's Reputation
Rate the quality of this post and help PurdueGuy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 12-13-2012, 01:14 AM   #3
ninetynineSC2
1999 SC2
Yup ECTS is brass. Its just a hair over 1/4. Did some more research and I think I'll borrow my dads scantool this weekend and see what the temp is when its warmed up (Didn't know some of the S series guages can be so far off from one another and the car still be at the right temp). I'm only just now concerned because my mpg's seem lower than last winter. This summer I averaged around 33-34 (Which compared to what others are getting seems low to me) and that was with very fuel economy minded driving. Might also check the ECTS connector for corrosion I might not have noticed when I replaced the sensor while I'm under the hood.
Current:
1999 SC2, 186,XXX
Past:
Old 12-13-2012, 03:10 AM   #4
mizzly
mizzly is on a distinguished road
1996 SL2
I had no heat on my 96 sl2. The gauge went to 1/4.
Changed the thermostat first and it didn't help the heat or raise the temp gauge.
Had the heater core flushed and now I have great heat but the gauge still reads a hair over 1/4. I have decided the gauge is probably wrong.
At least i have heat
Add to mizzly's Reputation
Rate the quality of this post and help mizzly reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mizzly is offline   Reply With Quote
Old 12-13-2012, 08:51 AM   #5
anmasher
anmasher has a spectacular aura aboutanmasher has a spectacular aura aboutanmasher has a spectacular aura about
anmasher's Avatar
1996 SL2
Mine was the exact same until I replaced the thermostat earlier this week. Now it goes to just before the 1/2 mark.
Yes, and you should... of course YMMV
Add to anmasher's Reputation
Rate the quality of this post and help anmasher reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
anmasher is offline   Reply With Quote
Old 12-13-2012, 09:52 AM   #6
The scanner is a good idea - if you have good heat, it sounds like the tstat is working.
When my tstat died, I had almost no heat in the cabin for maybe 15~20 minutes and I lost 1~2 mpg
But keep in mind, the scanner relies on what the PCM reads from the ECTS, so a bad ECTS or connector will mean the PCM is reporting the temp incorrectly.
Old 12-13-2012, 10:49 AM   #7
ninetynineSC2
1999 SC2
Thats why I figured if it didn't seem quite right on the scanner I'd check the ECTS connecter and see what it looks like. Start with the free stuff
Current:
1999 SC2, 186,XXX
Past:
Old 12-13-2012, 03:25 PM   #8
ninetynineSC2
1999 SC2
Quick question for when I'm checking the temp tomorrow. If it seems WAY off on the scanner I might stick a thermometer in the coolant tank and compare the two. Anyhow, I know Saturns either have the stock 185 or 195F, what is considered normal temp for the coolant when its warmed up? (I would assume 185/195 depending on which T-Stat but I don't know much about cooling systems )
Also, now that I think about it I don't think I've ever had the cooling fan come on (Don't think the cars ever gotten hot enough to need it) The highest the gauge has ever gone was 1/2 when sitting in traffic and that only happened once. I'll post the temp it's reading at and see what you guys/gals think of it as far as it being a normal temp.
Current:
1999 SC2, 186,XXX
Past:
Old 12-13-2012, 04:05 PM   #9
RobertGary1
1996 SC2
There are far too many other environmental factors that could affect the perceived amount of heat to conclude that the tstat is working.
Understand that the bulk of the aftermarket tstats out there are the wrong temp. Saturn says 192 yet most places are selling around 180. You may just have the wrong one.
-Robert
Old 12-13-2012, 05:04 PM   #10
ninetynineSC2
1999 SC2
I think I might be worrying about nothing. http://i202.photobucket.com/albums/a...empreading.jpg <--My needle is about a needlewidth short of that normally. Maybe the I'm just thought I was getting better mpg's last winter I'll still do the temp check and be sure though. (Maybe I baby my car a little TOO much )
Current:
1999 SC2, 186,XXX
Past:
P0037 and P0133 after T-stat replacement sean882 S-Series Tech 6 12-07-2012 09:07 AM
Question on replacing t stat neo7333 S-Series Tech 24 08-25-2012 01:54 PM
T-stat question Beachbaby902 S-Series General 23 08-22-2012 05:17 PM
Another MPG tank after T-stat replacement gearhead S-Series Tech 4 02-12-2011 01:35 PM
coolant fill after t-stat replacement greaseball Vue Tech 4 07-05-2010 09:09 AM
