Old 10-24-2012, 10:41 AM   #1
ericfragola
ericfragola is on a distinguished road
1998 SL1
Idea timing cover gasket options
Hey guys! I just got my new cylinder head from J&C! Cant wait to put it in. While I'm doing this, I decided to replace the timing components. I hate using rtv...absolutely hate it. Is there anything else I could use as a substitute to seal the timing cover? I'll definitely use it on the bottom part of the cover though that comes in contact with the oil pan. At oreilly auto parts they sell gasket material sheets. And there's ones specifically for oil. Could I use that instead of rtv?
Thanks!
Add to ericfragola's Reputation
Rate the quality of this post and help ericfragola reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ericfragola is offline   Reply With Quote
Old 10-24-2012, 12:16 PM   #2
Default Re: timing cover gasket options
You could try Hylomar Ultra Blue Racing formula. OldNuc recommended this stuff (first time I saw it was, I think, in the epic cboss thread, has "p0172" in the title)
Permatex sells it under their name, too
I'm a big fan of it. Done two covers with it, no leaks. Very easy to work with and clean up.
Old 10-24-2012, 05:45 PM   #3
ericfragola
1998 SL1
is it a make your own gasket type of thing? I'm looking more into the sheets that o could cut out, versus a tube of gasket maker
Old 10-24-2012, 06:36 PM   #4
97RedSaturnSC2
97RedSaturnSC2 is on a distinguished road
1997 SC2
1996 SC2
they dont make a gasket because it would be so thin in most areas and probably prone to leaking. ive use standard grey rtv on practically everything and have never had a problem with leaks. ive done 2 saturn builds and its the only sealant i use. the key is to use the correct amount and not over due it where itll ooze out and go places it shouldnt.
Add to 97RedSaturnSC2's Reputation
Rate the quality of this post and help 97RedSaturnSC2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
97RedSaturnSC2 is offline   Reply With Quote
Old 10-24-2012, 08:11 PM   #5
ssicarman
ssicarman's Avatar
You need to use a good quality RTV. If you use a paper type gasket it will move the timing cover out from the block and not let the oil passage orings seal properly. If this happens then your oil pressure will zero.
Add to ssicarman's Reputation
Valve cover gasket--preventing RTV from bonding to rubber gasket? PlasticCarsRock S-Series Tech 3 09-09-2012 10:38 PM
Timing Chain Cover Gasket Replacement.. and other things SaturnNJeep S-Series Tech 8 06-08-2010 03:28 PM
timing chain cover gasket sc2dohc94 S-Series Tech 2 03-20-2008 04:28 PM
cracked head,valve cover gasket or cam gasket leaking ???how to tell !! maestro S-Series General 11 06-04-2006 03:26 AM
Timing chain cover gasket? Mog Miscellaneous Tech 5 05-24-2004 08:51 PM
