Old 09-23-2012, 09:30 PM   #1
03SatGuy
03SatGuy is on a distinguished road
Default Traction Control light stays on constant
I have an 03 L-300 and the Traction Control light stays on constant. Might there be a problem in the traction control?
Add to 03SatGuy's Reputation
Rate the quality of this post and help 03SatGuy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
03SatGuy is offline   Reply With Quote
Old 09-24-2012, 12:03 AM   #2
fdryer has much to be proud offdryer has much to be proud offdryer has much to be proud offdryer has much to be proud offdryer has much to be proud offdryer has much to be proud offdryer has much to be proud offdryer has much to be proud offdryer has much to be proud offdryer has much to be proud of
Default Re: Traction Control light stays on constant
Can you turn TC off (by depressing the TC button)? Is the ABS indicator ON with the engine running?
Old 09-24-2012, 09:50 AM   #3
03SatGuy
Yes I can turn it off using the button and no the ABS light is not on.
Old 09-24-2012, 10:18 AM   #4
Well, unless yours is different from mine, its normal for the TC light to be on. For whatever reason GM and their 'ergonomics' people sat around to decide on how best to confuse the public, TC is programmed to be ON/available at all times. Manually pushing the TC button to turn it off is at the option of the driver to disable traction control. In the real world driving environment there are a few instances where traction control will be felt where the gas pedal seems to be disconnected due to TC taking over the electronic throttle; attempting to 'peel' rubber when the light turns green on wet/slippery/icy/slushy/oiled road ways, attempting to spin the front wheels when stuck in snow while trying to move out of a parking spot, and attempting to spin wheels on dirt/gravel roads. Each situation is an attempt to force wheel spin and each front wheel is turning faster than the rear wheels where the ABS/TC system is comparing front wheel speed to rears. Any wheel spinning faster than the slowest wheel is determined to be slipping and traction control removes control of the electronic throttle from the driver by; reducing electronic advance, sequentially cutting fuel injectors, and activate ABS to stop wheel spin in extreme situations. All to reduce wheel spin so all four wheels turn at the same speed while allowing just enough throttle to accelerate without wheel spin.
There are few instances of drivers realizing TC activates and saves them from grief while many more deplore TC and manually turn it off to have more control.
Old 09-24-2012, 10:35 AM   #5
03SatGuy
Thank you. I thought I read somewhere that it is suppose to only light up when TC is actually engaging. I don't have a need for spinning tires and hotrodding so no big problem.
Old 09-25-2012, 01:10 AM   #6
Jonnyferrari
Jonnyferrari is on a distinguished road
Jonnyferrari's Avatar
2000 L-Series 3.0L Sedan
Mine only lights when I am spinning out on ice, sliding down a hill or doing a burnout, so it is not the case with me.
Proud owner of 2000 Saturn LS2 premium package; HELP ME KEEP IT ALIVE!! @105k
Add to Jonnyferrari's Reputation
Rate the quality of this post and help Jonnyferrari reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Jonnyferrari is offline   Reply With Quote
Old 09-26-2012, 11:49 AM   #7
spencerb
spencerb will become famous soon enough
spencerb's Avatar
2008 Astra XR
The light on the switch on the center dash console should be on all the time to indicate that the traction control system is "ready." You can turn it off manually.
If the traction control activates when a tire spins, you will see a different light flash in the instrument cluster. It only comes on when the system is actively trying to control wheel spin.
2002 L200
2005 Honda Odyssey EX-L
Past Saturns: 97 SL2, 01 SC2, 04 VUE, 08 Astra.
Add to spencerb's Reputation
Rate the quality of this post and help spencerb reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
spencerb is offline   Reply With Quote
Traction Control Light? RicksVue Vue Tech 3 09-03-2010 09:32 PM
Traction Control Active light stays on. hit_n_run S-Series Tech 7 05-19-2010 01:19 PM
Traction Control Light stays on In my '07 Relay! tgandnine Relay Tech 4 07-31-2008 02:52 PM
abs light on no traction control nascardemon L-Series Tech 5 11-03-2006 03:02 PM
New PCM, "Traction Active" light now stays on bryan_johnson S-Series Tech 5 10-03-2005 05:01 PM
