Old 08-26-2012, 09:25 PM   #1
hise0001
hise0001 is on a distinguished road
Default 2002 L100 BCM - Does it HAVE to be reprogrammed
We have a 2002 L-100 and it looks like the bcm is going bad. My daughter was driving down the road and the gas gauge dropped to empty, low fuel warning sounded, and then gauge went back to full... security light was flashing and then stopped. Its been driving fine since then however, we just noticed the odometer reset to 000000 miles.
so, my questions are:
1. can I replace the bcm myself.
2. where's located?
3. do I HAVE to have it programmed (other than the 30 minute DIY procedure)
I already have a branded title (salvage vehicle) so I don't care about mileage being off... It's going to the junk yard when I'm done with it. But, is there anything else I should be concerned about doing a basic DIY reprogram of a new bcm?
Add to hise0001's Reputation
Rate the quality of this post and help hise0001 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hise0001 is offline   Reply With Quote
Old 08-27-2012, 12:29 AM   #2
Default Re: 2002 L100 BCM - Does it HAVE to be reprogrammed
1-You can replace the bcm (on top of the glove box) but only with a used one already programmed. Mileage stays with used bcm's. The 30-minute relearn is for this purpose.
2-You cannot program or buy a new bcm. Only GM will replace a bcm with a new one and program it as its only programmable using GM's Tech II tool.
There's no re-programming of any bcm's. Search past threads about bcm issues.
Is my BCM going bad? 2002 L100 radioouman L-Series Tech 3 08-11-2008 10:33 PM
2002 L100 kalmss L-Series Tech 4 01-05-2008 08:56 PM
2002 l100 paulryan L-Series Tech 2 12-22-2007 05:17 PM
2002 L100 SE in MN Dhorn33 Classifieds 0 10-26-2004 03:05 PM
Reprogrammed PCM ?s ProDarwin Mods and Performance 1 05-12-2003 01:02 PM
