Old 06-23-2012, 07:40 PM   #1
brags
brags will become famous soon enoughbrags will become famous soon enough
1996 SL1
Default Does the A/C on Saturns shut off under W.O.T?
On my 96 saturn SL1 it has A/C that works cold still but my Question is
does the A/C under W.O.T or (wide open throttle ) shut off.? then return
to cold as You ease back up on the gas to normal.?
" Any man that doesen"t share his knowledge in cars is wrong to do !"
Add to brags's Reputation
Rate the quality of this post and help brags reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
brags is offline   Reply With Quote
Old 06-23-2012, 07:45 PM   #2
Luthin
Luthin is on a distinguished road
Luthin's Avatar
Default Re: Does the A/C on Saturns shut off under W.O.T?
When my AC still worked I noticed the same thing on my car, so I'm assuming yes. But that's just based on my observations and not anything scientific/known fact.
Add to Luthin's Reputation
Rate the quality of this post and help Luthin reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Luthin is offline   Reply With Quote
Old 06-23-2012, 07:54 PM   #3
ssicarman
ssicarman is a name known to allssicarman is a name known to allssicarman is a name known to allssicarman is a name known to allssicarman is a name known to allssicarman is a name known to all
ssicarman's Avatar
The AC will shut down at about 90 to 95% throttle and will stay off for about 15 seconds.
Add to ssicarman's Reputation
Old 06-23-2012, 08:20 PM   #4
simkid5614
simkid5614 is on a distinguished road
simkid5614's Avatar
Not exactly WOT but after 4-5000 RPM it will, So if you're in the range of racing at WOT it will stay off till you blip off the throttle.
2002 SL2 115k "Whisper" No leaks!! :) 115 and going strong..
Add to simkid5614's Reputation
Rate the quality of this post and help simkid5614 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
simkid5614 is offline   Reply With Quote
Old 06-24-2012, 07:41 AM   #5
brags
1996 SL1
OK.. so the A/C compressor under load shuts off im guessing..? to not
take away horsepower when the engine is under Load at W.O.T ?
Old 06-24-2012, 12:06 PM   #6
fdryer has much to be proud offdryer has much to be proud offdryer has much to be proud offdryer has much to be proud offdryer has much to be proud offdryer has much to be proud offdryer has much to be proud offdryer has much to be proud offdryer has much to be proud of
Wide open throttle = no a/c. Release throttle back to normal driving and it may take up to 15 seconds before a/c resumes cooling. Approximately 7hp is used to drive the a/c compressor. The pcm knows from throttle position sensor feedback to decide when to cut off power to the compressor and when to return a/c function.
*The CPS is the heart of the entire EFI system. No cps = dead EFI system*
*There's more to a/c than just a few cans of refrigerant*
*There's more to brakes than just replacing parts*
Old 06-24-2012, 01:30 PM   #7
brags
1996 SL1
guess its after all a normal thing for the A/C to do..on these
cars wich makes Perfect sense as far as having it work at a normal Level
of operation. as opposed to shutting it off at wide open throttle for more
demanding needs. Big Thanks To ALL that posted especially fdryer Thanks.!
'99 SW2 shut down LGM84 S-Series Mods 9 04-07-2011 09:15 PM
How do I fix this/shut it off?? sprinj76 S-Series Tech 7 04-04-2008 02:19 PM
Vue shut down 357bob General Saturn Discussion 4 12-25-2007 12:25 PM
15 Min & shut Down jk092201 L-Series Tech 8 08-09-2006 08:32 AM
Car won't shut off i81b4u81 L-Series Tech 2 11-24-2005 09:27 AM
