Old 06-20-2012, 05:56 PM   #1
02 Dawg
02 Dawg is a jewel in the rough02 Dawg is a jewel in the rough02 Dawg is a jewel in the rough02 Dawg is a jewel in the rough
02 Dawg's Avatar
2002 VUE 3.0L
Default Battery Light Flashing
The battery light on the dash of my 02 3.0 Vue comes on then goes off. Sometimes it just stays on for a few miles then begins to go off and on.
Could it be the alternator going bad or does the belt need to be adjusted?
Also were is the alternator located? And how do you adjust the belt?
Thanks for any help,
Add to 02 Dawg's Reputation
Rate the quality of this post and help 02 Dawg reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
02 Dawg is offline   Reply With Quote
Old 06-20-2012, 07:06 PM   #2
Chazberry
Chazberry's Avatar
Default Re: Battery Light Flashing
Sounds like your Alternator is on it's way out. Measure your Battery voltage if you can catch it when the light is on.
No adjustment - the Tensioner keeps it tight. If the Tensioner was weak, you would probably hear some squealing.
It's mounted on the firewall side of the Engine - down low.
Add to Chazberry's Reputation
Old 06-20-2012, 09:17 PM   #3
02 Dawg
02 Dawg's Avatar
2002 VUE 3.0L
Thank you for your help. I checked around and the alternators go for about $175.00 Does anybody know were to buy one cheaper? The last couple of months I have put a ton of money in this vehicle.
Thanks again for your help.
No adjustment - the Tensioner keeps it tight. If the Tensioner was weak, you would probably hear some squealing. I have no noise in the engine area,
Is the alternator hard to get at?
Old 06-20-2012, 09:21 PM   #4
02 Dawg
02 Dawg's Avatar
2002 VUE 3.0L
Just wondering if it could be the voltage regulator?
Old 06-20-2012, 09:31 PM   #5
Chazberry
Chazberry's Avatar
It's not too bad. It looks like there isn't enough room to pull it out between the stabilizer bar or some other obstructions, but it IS possible to turn it just the right way to get it down. There is no separate Regulator. I'm not sure but I think the ECM might handle that function. I remember paying >$200 for mine.
Old 06-20-2012, 10:22 PM   #6
02 Dawg
02 Dawg's Avatar
2002 VUE 3.0L
Can I just buy the brushes?
Old 06-21-2012, 05:48 AM   #7
Chazberry
Chazberry's Avatar
It could be a Diode that's failing. How many miles on your VUE?
Old 06-21-2012, 12:06 PM   #8
02 Dawg
02 Dawg's Avatar
2002 VUE 3.0L
The Vue has 115,000 on it.
Old 06-21-2012, 12:24 PM   #9
far2grumpy
far2grumpy's Avatar
Call a few local parts houses to find who can load test generator output.
Do you know condition of the battery?
Are battery cables free of corrosion?
Does the starter have plenty of zip when engine cranks?
The Vue is 10 - 11 years old but 115K sounds young for generator failure.
Old 06-21-2012, 09:33 PM   #10
02 Dawg
02 Dawg's Avatar
2002 VUE 3.0L
Today the alternator stopped working all together and the Vue was low on power and when I shut the car off it wouldn't restart. I took the alternator off and had it tested and they told me the output was low and under load it couldn't keep up with charging the battery. The shop is going to rebuild my original alternator for $85.00
I hope this solves my problem.
Flashing battery light not fixed by new battery. enviroko General Saturn Discussion 5 12-17-2015 12:05 PM
Battery light flashing/ solid augerblade Ion General 1 11-18-2010 02:56 PM
Temp & Battery light Flashing...what does it mean? pasha S-Series Tech 5 01-19-2006 07:42 PM
Intermittent flashing of low battery / temp light enganeer S-Series Tech 7 10-28-2002 12:52 PM
Low battery/Temp light flashing intermittently cron S-Series Tech 4 05-07-2000 07:38 PM
