Old 06-07-2012, 09:15 AM   #1
NE-ll-123
NE-ll-123 is on a distinguished road
Sad How to Replace the Ignition Switch
Hi, I have a 98 SL1, 5 speed with 185,000 miles.
I need to replace the Ignition Switch, not the key cylinder.
I have the covers around the steering column removed, and can get to the Ignition Switch.
There are 2 screws holding it onto the key cylinder housing. I can loosen the lower screw, but as I back it out, it hits a metal bracket, and I can't get it out any farther.
Can anyone tell me what the next step is? Do I need to remove the steering wheel, and other parts to be able to get the whole Ignition Switch-Key Cylinder assembly out?
Thanks for your help.
Add to NE-ll-123's Reputation
Rate the quality of this post and help NE-ll-123 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
NE-ll-123 is offline   Reply With Quote
Old 06-07-2012, 03:01 PM   #2
ShawnV
ShawnV is a jewel in the roughShawnV is a jewel in the roughShawnV is a jewel in the roughShawnV is a jewel in the rough
ShawnV's Avatar
2000 SW2
Default Re: How to Replace the Ignition Switch
Take a crescent wrench to that metal piece and tweak it out of the way.
http://www.saturnfans.com/forums/sho...9&postcount=50
Add to ShawnV's Reputation
Rate the quality of this post and help ShawnV reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 06-09-2012, 06:32 PM   #3
NE-ll-123
Happy Re: How to Replace the Ignition Switch
Thanks Shawn, good idea. I'll do that.
Old 06-11-2012, 07:53 PM   #4
adventureoflink
adventureoflink's Avatar
Actually, I never messed with that metal piece when I did mine. Get yourself a Craftsman 5.5mm ignition box wrench and you're good to go
There's one for sale on Grainger.com; catalog ID# 19D016
http://www.grainger.com/Grainger/CRA...-Wrench-19D016
and Shawn, what exactly does that metal piece control? Is that for the tilt steering, or is it unnecessary, or..?
97 SL2
DOB: 3/19/97
Date Obtained: 5/30/07
Status: Alive, 1/2 exhaust
2004 Merc G.Marquis GS
DOB: 2/4/04
Date Obtained: 7/6/12
Status: Alive, no heat
Add to adventureoflink's Reputation
Rate the quality of this post and help adventureoflink reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
How to replace ignition switch? brokendown S-Series General 4 04-04-2012 02:29 AM
'94 SL2 Need to replace ignition switch and can't turn key! phroomis S-Series Tech 6 09-16-2011 11:35 AM
Time to replace ignition switch and pwr steering motor merc Ion Tech 2 05-04-2011 05:56 PM
'94-SL1 - ignition key in switch chime - ignition switch bezel question wrchism S-Series Tech 1 01-24-2005 01:09 AM
replace ignition switch davem S-Series Tech 4 10-08-2002 09:30 AM
