Old 07-16-2008, 02:02 PM   #1
cfwperks
cfwperks is on a distinguished road
2003 ION-3 Sedan
Default Serpentine Belt
My belt is down to its last thread! I've replaced the belt on my old Explorer a few times, easy job, but does the ION have a self tensioner and if so any tricks on getting it on! It looks like a tight spot! Thanks!
Add to cfwperks's Reputation
Rate the quality of this post and help cfwperks reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cfwperks is offline   Reply With Quote
Old 07-16-2008, 04:35 PM   #2
bc3tech
bc3tech will become famous soon enough
bc3tech's Avatar
2007 AURA XR
2007 Outlook XR
Default Re: Serpentine Belt
Yes it has a tensioner, you take off the wheel well shroud (and wheel of course) on the passenger side, then use a 3/8" breaker bar (easiest way) to pull on the tensioner and release the belt. easy as pie.
+rep always appreciated!
The Procharged Ion - http://kickassion.bc3tech.net
16.317s @ 85.30mph (Nearly stock)
188.28whp / 175.03wtq - SMP Stage 2 - 10psi
Add to bc3tech's Reputation
Rate the quality of this post and help bc3tech reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bc3tech is offline   Reply With Quote
Old 07-16-2008, 05:22 PM   #3
Maritime Storm
Maritime Storm is on a distinguished road
Maritime Storm's Avatar
2003 ION-2 Sedan
Trying to change it from the top can be done with considerable use of profanity(this actually my prefered method). However if you not a regular user of profanity, it is easier from the bottom.
Save the Earth, Ban Slushboxes!!!!!
Add to Maritime Storm's Reputation
Rate the quality of this post and help Maritime Storm reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Maritime Storm is offline   Reply With Quote
Old 07-17-2008, 02:33 PM   #4
SL2-Guy
SL2-Guy is on a distinguished road
SL2-Guy's Avatar
2003 ION-2 Quad Coupe
So true man.. I think i used every word in the book to get that belt off from the top... And now i find out you can get it from the bottom
Took it off since Saturn told me it was worn out pretty bad... When i took it off and checked it; it was still brand new
Add to SL2-Guy's Reputation
Rate the quality of this post and help SL2-Guy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SL2-Guy is offline   Reply With Quote
Old 07-24-2008, 04:57 AM   #5
Maritime Storm
2003 ION-2 Sedan
Mine has 84K kms, and she been through 2 belts already. Changed it both times from the top, getting the belt off is easy, putting it on isn't bad providing the new belt isn't twisted in any way. The last one had a twist in it, took me about an hour & a half to change, with the right application of profanity it went into place. My saturn tech at work tells me they usually do them from below.
Old 05-30-2012, 06:46 PM   #6
buckeyegirl
buckeyegirl is on a distinguished road
2004 ION-1 Sedan
Checkered Flag Re: Serpentine Belt
Like BC3Tech said, (but I can not emphasize enough for you first time Ion belt changers) " you take off the wheel well shroud (and wheel of course) on the passenger side, THEN USE A 3/8" breaker bar (easiest way) to pull on the tensioner and release the belt. "
The standard 24" belt remover tool is too long, and the frame gets in the way when trying to turn the tensioner to release tension. You need a shorter version. The shorter tension remover tool in most kits are 1/2" however. It is the right length, but won't fit in the hole socket.
Once I bought the 3/8" breaker bar, was able to quickly reach up, move the tensioner with one hand and flip the belt around the AC. Rethread new belt. Move tensioner and flip belt. Done.
Add to buckeyegirl's Reputation
Rate the quality of this post and help buckeyegirl reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
buckeyegirl is offline   Reply With Quote
Old 05-30-2012, 08:11 PM   #7
2006 ion2
2006 ion2 will become famous soon enough
2007 ION-2 Sedan
call me a glutten for punishment, but my sister's grand prix with the 3100 had no room to do it, and I did it from the top. the ion has more room and less accessories/pulleys (by at least 2), so I'm going to try mine from the top, thank you very much.
2007 Saturn Ion 2
2003 Chevrolet venture lt
Add to 2006 ion2's Reputation
Old 05-30-2012, 08:37 PM   #8
Samtherecordman
Samtherecordman is on a distinguished road
Samtherecordman's Avatar
2007 ION-3 Quad Coupe
It looks so easy to do, just looking at the pictures.... definitely would need an extension if you do use a Belt Tensioner Unloader.
Saturn Ion 3 Quad Coupe 3 with Sports Appearance package with Aura Pro Bass Shakers under the front seats, Kenwood Excelon Mono Amplifier and Infinity Kappa Perfect and I'm In Heaven!!!!
Add to Samtherecordman's Reputation
Rate the quality of this post and help Samtherecordman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Samtherecordman is offline   Reply With Quote
Old 05-30-2012, 08:51 PM   #9
ssicarman
ssicarman is a name known to allssicarman is a name known to allssicarman is a name known to allssicarman is a name known to allssicarman is a name known to allssicarman is a name known to all
ssicarman's Avatar
Nearly four year old thread brought back to life. Why?
Add to ssicarman's Reputation
Old 06-02-2012, 01:38 PM   #10
chilipepper1327
chilipepper1327 is on a distinguished road
chilipepper1327's Avatar
2006 ION-3 Quad Coupe
We are all human and don't always clue in on the dates...
Add to chilipepper1327's Reputation
Rate the quality of this post and help chilipepper1327 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
chilipepper1327 is offline   Reply With Quote
Old 06-02-2012, 05:59 PM   #11
Samtherecordman
At least Old Threads don't grow mold on them after a while.... always handy to have reference to them at a later time. ;-)
About serpentine belt and belt tensioner xybaby S-Series Tech 5 01-04-2010 10:42 AM
Timing Belt And Serpentine Belt obsidian52 L-Series Tech 3 06-06-2009 08:23 AM
Serpentine belt hawthorne Vue Tech 1 03-26-2009 08:52 PM
Serpentine belt tfbthg S-Series Tech 6 06-06-2007 11:37 PM
Serpentine Belt 1999-SL2 Miscellaneous Tech 3 06-14-2001 08:11 AM
