Old 05-08-2012, 08:59 PM   #1
wh04vue
wh04vue is on a distinguished road
Default Water pump leaking
Hi , just noticed that my water pump is leaking so I guess I should do timing belt , tensioner at the same time . My 3.5 liter Vue has 152 km and all said parts are original . Does anyone have an idea of the cost to have this job done in the Toronto area .
Thank you
Add to wh04vue's Reputation
Rate the quality of this post and help wh04vue reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
wh04vue is offline   Reply With Quote
Old 05-09-2012, 07:58 AM   #2
RedGeminiPA
RedGeminiPA will become famous soon enough
RedGeminiPA's Avatar
2004 VUE 3.5L
Default Re: Water pump leaking
That sounds a little premature. You're at 94,448 miles - 5,500 shy of the 100k job. Are you 100% sure it's the water pump?
A dealer will be outrageous. Best of luck finding a garage who actually knows what they're doing. Keep us updated.
Avid Apple, car and vacuum enthusiast. Don't hate! ;)
Current:
'04 FWD 3.5L
Previous:
'05 AWD Red Line
'02 L200
http://www.facebook.com/SaturnFansNorthEast
Add to RedGeminiPA's Reputation
Rate the quality of this post and help RedGeminiPA reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RedGeminiPA is offline   Reply With Quote
Old 05-09-2012, 08:46 AM   #3
mikec
mikec will become famous soon enough
mikec's Avatar
I just had my timing belt/water pump/plugs done on my Vue at a GM dealer and I only had 93K. It was about $1200. Better safe than sorry.
Add to mikec's Reputation
Rate the quality of this post and help mikec reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mikec is offline   Reply With Quote
Old 05-09-2012, 09:33 AM   #4
far2grumpy
far2grumpy is a name known to allfar2grumpy is a name known to allfar2grumpy is a name known to allfar2grumpy is a name known to allfar2grumpy is a name known to allfar2grumpy is a name known to all
far2grumpy's Avatar
2005 VUE 3.5L
2007 VUE 3.5L
The 100,000 number for 3.5 timing belt service is not set in stone.
Depending on where you live (climate-wise), and what you do with the Vue (tow), you could be a candidate to change timing belt at 50,000 miles.
Its short-sighted to expect the 100K number to apply to all Vue's.
Not a professional mechanic - advice and data are free - PM email address if I'm not logged on.
Leaking coolant, I think it's the water pump Seņor Ramos S-Series General 21 09-03-2009 05:01 PM
water pump leaking bdokeefe S-Series Tech 5 05-27-2008 07:35 AM
Could this be my water pump leaking? (pics) ecaryn S-Series Tech 10 09-19-2007 11:01 PM
Leaking Water Pump edlee S-Series General 7 12-11-2005 07:23 AM
Water Pump is leaking Engine Oil SatMan41 L-Series Tech 2 05-29-2004 01:48 PM
