#1 | ||||
![]() Join Date: Aug 2011
2004 ION-1 Sedan
1994 SL2
There are 2 of these , one on each side of the radiator on my 2004 Ion sedan.
Thanks ![]()
#2 | ||||
![]() Join Date: Jun 2011
2004 ION-2 Sedan
Probably impact sensors if the radiator gets smashed in to activate the airbags, that's my guess, someone else probably knows better than I though
... 2004 ION 2 Sedan -Autozone short ram -FE5 Suspension with Pedder springs -4300k Hi-lo HID -OPTX green underglow -35% tint all around -Kicker Audio all around
#3 | |||||
2004 ION-1 Sedan
1994 SL2
The car in the pic with the mystery items is an Ion 1 with an automatic trans and the car that doesn't have them is an Ion 2 with a manual trans. There are little differences between the 2 cars,I'll check and see if I can find them mounted elsewhere. Thanks for the input.
#4 | ||||
![]() Join Date: Feb 2008
DRL (Daytime Running Light) resistor.
#5 | ||||
2004 ION-1 Sedan
1994 SL2
Thank You ,(guess I should have Googled the number).
I guess the other car has them mounted in another place or it doesn't have DRLs.
#6 | ||||
all ions have drls, iirc, all saturns ever do.
... 2007 Saturn Ion 2 2003 Chevrolet venture lt trifecta dealer for the U.P. and WI. There is no two door ion. Proudly driving one of the last saturns produced before gm killed the brand.
#7 | ||||
2004 ION-1 Sedan
1994 SL2
Thanks guys for the info. I can't find them on the other car but I'm not that concerned about it now.
My initial concern was because I thought they might have been air bag sensors and the one on the drivers side was pointed up at a 45 degree angle,which I thought might be a concern but since its only a resistor I'm moving on with reassembling the nose. Thanks Again.
#8 | ||||
The DRL resistors were part of a fix for DRL light socket problems in the first to second years of production. The later years had the resistors built in.
... A lousy day in paradise is still a day in paradise.
#9 | |||||
2004 ION-1 Sedan
1994 SL2
Where are "built in" resistors,car harness or headlight assembly ? Thanks for the info.
#10 | ||||
they're both 04s, so they neither should have the built in resistors. it sounds like your second ion was never "fixed".
#11 | ||||
2004 ION-1 Sedan
1994 SL2
Ahh.......... is there a danger if its not fixed ?
#12 | ||||
I believe they were burning out bulbs and sockets. so, yeah, I would have a dealership confirm if the TSB applies to your second ion.
#13 | ||||
2004 ION-1 Sedan
1994 SL2
Thank You
| Thread Tools | |
| Display Modes | |
