Old 05-07-2012, 08:21 AM   #1
sheller712
sheller712 is on a distinguished road
Default 2005 Saturn Ion Ignition Problems
I have had ongoing problems the ignition on my saturn. First issue was with the key getting stuck in the ignition when in park, then the key getting stuck with car running and not turning off, and now key will not turn all the way and car won't start. The key will turn half way so that lights & radio come on but then is stuck. Over the past year, I have had theignition switch assembly replaced (5/11), the lock cylinder assembly replaced twice (5/11 & 1/12), and the ignition housing replaced (1/12).
Any other ideas on what the issue may be?
Thanks!
Add to sheller712's Reputation
Rate the quality of this post and help sheller712 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sheller712 is offline   Reply With Quote
Old 05-07-2012, 09:38 AM   #2
SilverSpectre
SilverSpectre is on a distinguished road
SilverSpectre's Avatar
2007 ION-3 Quad Coupe
2006 VUE 2.2L
Default Re: 2005 Saturn Ion Ignition Problems
Thanks!
This tends to be a pretty common issue with the ignition switches. The only thing I have heard of that fixes this problem is replacing the ignition switch (which ironically you have already done).
2007 Saturn Ion 3 QC - "The Silver Spectre"
Resurrected 12/29/11
OZ Allegerita Wheels, FE5 Suspension w/ adjustable end links, Eibach Pro Kit, Progress Rear Sway Bar, TWM Short Shifter
Add to SilverSpectre's Reputation
Rate the quality of this post and help SilverSpectre reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SilverSpectre is offline   Reply With Quote
Old 05-07-2012, 05:05 PM   #3
DigitalSaturns
DigitalSaturns is on a distinguished road
One of my keys did this. It was the key I used all the time. Spare key worked fine, had dealer cut a new key and now they both work fine.
Add to DigitalSaturns's Reputation
Rate the quality of this post and help DigitalSaturns reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
DigitalSaturns is offline   Reply With Quote
2005 Saturn Ion 2 - Ignition always "on" 239bmxican Ion Tech 4 05-14-2011 10:03 AM
2005 Relay 3 ignition replacement Roon81 Relay Tech 0 04-26-2011 02:11 PM
2005 Saturn Vue problems mcanous Vue Tech 2 04-18-2011 02:11 PM
2005 Saturn Ion3, Is my Ignition Lock Cylinder bad? CatfishJohn Ion General 13 02-16-2009 10:03 PM
98 Saturn SL Ignition/Starting problems pykee S-Series Tech 4 02-25-2008 11:53 PM
Copyright ©2000 - 2016, vBulletin Solutions, Inc.
