Old 05-06-2012, 08:55 PM   #1
robby562
robby562 is on a distinguished road
2000 SL2
Default Horn not working
I have a 2000 Saturn SL2 and the horn has never worked since I got it used. Never needed it really but I thought I should look into it.
Horn doesn't work and when I push on the steering wheel, I heard a clicking noise coming from the horn relay located in the fuse box under the hood.
So would I need a new relay or horn?
Add to robby562's Reputation
Rate the quality of this post and help robby562 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
robby562 is offline   Reply With Quote
Old 05-06-2012, 09:09 PM   #2
robby562
2000 SL2
Default Re: Horn not working
I read I can swap the horn relay with one of the other relays such as the AC to test it but I wasn't too sure if it was removable and didn't want to mess with it.
I'm not car savvy.
Old 05-06-2012, 09:22 PM   #3
cityhawk
cityhawk will become famous soon enough
cityhawk's Avatar
1993 SW2
2001 L-Series 3.0L Wagon
Yes, you can swap the relays for testing purposes. I used the horn relay to test my cooling fan. I do know that the underhood relay/fuse box looks different on the later S-series than it does on my gen 1 1993. However, just find a relay that looks the same and try it out (on the gen 1's the horn and fan relays are interchangeable). They just pull out/unlplug with a little gentle wiggling. You shouldn't have to use too much effort.
Saturns:
1993 SW2 MT
2001 LW300
Gone but not forgotten: 1999 SW2 MT
Project cars:
1928 Ford Model A Tudor Sedan
Add to cityhawk's Reputation
Old 05-06-2012, 11:08 PM   #4
PurdueGuy
PurdueGuy's Avatar
1999 SC2
1999 SC1
I believe '00 was the first year they went back to the 2-wire horn, which is a good thing. Do you have keyless entry? If so, hitting lock repeatedly would normally honk the horn on the 2nd lock (though hitting it very rapidly might take several presses before it would honk). Just another way of testing the horn, in case the button on the steering wheel were broken. Do the relay swap & test. could be a bad horn, and since it's a 2-wire (unless I'm remembering the years wrong), you can use pretty much any aftermarket horn with little to no modification.
SaturnSeries.net owner
Add to PurdueGuy's Reputation
Old 05-08-2012, 12:55 PM   #5
robby562
2000 SL2
Switched the relays and still didn't work, even when pressing the key fob you just hear a clicking noise so I'm guessing the horn is dead.
Old 05-08-2012, 09:11 PM   #6
mattwithcats
mattwithcats is on a distinguished road
2001 SL2
Replace with a Wolo Bad Boy,
Loud as heck, 120 db...
http://www.amazon.com/Wolo-Model-419.../dp/B000F5DQWY
Horn Not working gdlvnman S-Series General 8 11-16-2011 11:30 AM
02 Vue Horn not working Andyec Vue General 1 03-28-2011 09:37 PM
Horn not working tom_94305 S-Series Tech 3 08-27-2010 01:05 PM
'02 VUE Horn NOT Working dpware Vue General 7 04-19-2010 01:27 PM
Horn not working hlp plz! Salsa88 S-Series Tech 12 12-27-2007 10:38 PM
